17268 Discussions
[B]ERROR:object "std_logic_signed" is used but not declared[/B]
hi there,
I'm VHDL beginner working on a Filter code, which is shown below and i'm getting the error as "error (10482): vhdl error at fir.vhd(17): object "std_logic_signed" is used but not declared" but i believe i included proper libraries , please help me solve this issue
code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
--use std_logic_signed.all;
use ieee.numeric_std.all;
--use ieee.numeric_std_signed.all;
entity fir is
port(clk : in std_logic;
rst : in std_logic;
din : in std_logic_signed(7 downto 0);
dout : out std_logic_signed(18 downto 0));
end entity;
architecture behavioural of fir is
subtype word is std_logic_signed(7 downto 0);
type coeff_type is array(7 downto 0)of word ;
signal coeff : coeff_type := ("11110110","00011110","00110110","01001001","01001001","00110110","00011110","11110110") ;
signal count : integer ;
signal count_ref : integer;
signal prev_op : std_logic_signed(18 downto 0);
signal i: integer ;
begin
process(clk,rst)
begin
if(rising_edge(clk)) then
if(rst = '1') then
dout <= "0000000000000000000";
count <= 0;
prev_op <= "0000000000000000000";
count_ref <= 0;
elsif(rst = '0') then
if(count = count_ref) then
if(i >= 0) then
prev_op <= prev_op + (din * coeff(i));
i <= i + 1;
count <= count + 1;
count_ref <= 0;
elsif(i = 8) then
dout <= prev_op;
count <= 0;
count_ref <= 0;
i<= 0;
end if;
elsif(count /= count_ref) then
count_ref <= count_ref + 1;
end if; ---for count
end if; --- for reset
end if; --- for rising edge
end process;
end;
Try this:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity fir is port(clk : in std_logic; rst : in std_logic; din : in signed(7 downto 0); dout : out signed(18 downto 0)); end entity;
Cheers,
Dave
that solved the error but i have a doubt , you removed arth.all library does my compiler understand the 8-bit signed multiplication i'm trying to perform in my code ? or is there any other library where the 8-bit signed multiplication is defined ?
Cheers
Siva
--- Quote Start ---
i have a doubt, you removed arth.all library does my compiler understand the 8-bit signed multiplication i'm trying to perform in my code ? or is there any other library where the 8-bit signed multiplication is defined ?
--- Quote End ---
Looks like its in the numeric_std library:
http://www.eda.org/rassp/vhdl/models/standards/numeric_std.vhd
Simulate and test :)
Cheers,
Dave
you cannot use std_logic_arith and numeric_std in the same file because they conflict. numeric_std is the IEEE standard package, std_logic_arith is not (so dont use it).
