17268 Discussions
Quartus 9.0 Support & Installation for ACEX 1K (EP1K50TC144-3) on Windows 11
Mariyam
We are looking for a software tool that supports place and route  and generates a programmable file for ACEX 1K (EP1K50TC144-3) devices.
We are using Windows 11, and it seems like Quartus 9.0 supports the ACEX 1K device. Please confirm whether Quartus 9.0 fully supports this device and works on Windows 11.
Additionally, Please share the Quartus 9.0 installation file or provide a download link?
Thanks in advance.
KennyTan_Altera
Since Quartus 9.0 is a discontinues software, we do not do any maintenance to support in windows 11. The supported OS will be as below:
The Quartus II Design Software is supported on the
following operating systems and versions:
  Windows XP SP2 32-bit
  Windows XP SP2 64-bit
  Windows XP Pro X64 Edition
  Windows Vista 64-bit
  Windows Vista 32-bit
  Red Hat Enterprise Linux 4.0 for 32-bit and for AMD64
   or Intel EMT64 64-bit CPUs
  Red Hat Enterprise Linux 5.0 for 32-bit and for AMD64
  SUSE Enterprise Linux 9/10 for 32-bit and for AMD64
  SUSE Desktop Linux 9/10 for 32-bit and for AMD64
  CentOS 4/5 for 32-bit and for AMD64
The ModelSim-Altera VHDL and Verilog HDL Simulation Tool is supported
on the following operating systems and versions:
  SUSE 9 Enterprise Linux 32-bit
  SUSE 10 Enterprise Linux 32-bit
The Nios II Embedded Design Suite is supported on the following
  Windows XP SP2
  Red Hat Linux Enterprise 4.0 for 32-bit and for AMD64
The Altera MegaCore IP Library is supported on the following
  Red Hat Linux 4.0 for 32-bit and for AMD64
  Red Hat Linux 5.0 for 32-bit and for AMD64
Let me know if you are fine with this before I request the software for you.
Kenny Tan
Mariyam
Thank you for the details. I understand that Quartus 9.0 is not supported on Windows 11.
Please proceed with the request and share the software file with me.
Thanks in advance.
Mariyam
FvM
because Quartus 9.0 has been released before newer Windows OS, supported OS are as specified in above quoted Quartus 9.0 "Software Requirements" (9.0/quartus/readme.txt). Nevertheless Quartus 9.0 (and even older versions) are working for me well under Windows 10. I'm not sure about Windows 11, but you still have the option to run Windows or Linux version in a virtual machine.
Frank
KennyTan_Altera
Hi Mariyam,
Kindly check your email on this, as it require quite some information for the process.
Kenny Tan
FvM
I can report that I see Quartus 9.0 working under Windows 11, both 32- and 64-Bit version. I was able to compile an old ACEX 1k design.
Frank
