Quartus Crash
Any suggestions? Of course I tried to delete /db and /incremental_db. The result is still the same
--- Quote Start ---
Problem Details
Error:
Internal Error: Sub-system: EMIF, File: /quartus/periph/emif/emif_gen5_phyclk_av.cpp, Line: 469
pll_lvds_output_atom && pll_lvds_output_atom->is_pll_lvds_output()
Stack Trace:
0x81dac: EMIF_GEN5_PHYCLK_AV::create_design + 0x3b4 (periph_emif)
0xfa88: PCC_ENV_IMPL::perform_op + 0x2ac (periph_pcc)
0xf746: PCC_ENV_IMPL::create_design + 0xda (periph_pcc)
0x2eab9: FSV_PERIPHERY_PLACEMENT_UTIL::do_auto_promote_io_std + 0xd9 (fitter_fsv)
0x21920: FSV_EXPERT::auto_promote_io_std_and_create_complement_pins + 0x50 (fitter_fsv)
0x2570d: FSV_EXPERT::fitter_preparation_pre_fpp + 0xc9d (fitter_fsv)
0x238e6: FSV_EXPERT::fitter_preparation + 0x26 (fitter_fsv)
0x1dfff: FSV_EXPERT_BASE::fitter_preparation_run_family_fitter_preparation + 0x4f (fitter_fsv)
0x1daf8: FSV_EXPERT_BASE::fitter_preparation + 0x68 (fitter_fsv)
0x1e750: FSV_EXPERT_BASE::invoke_fitter + 0x3b0 (fitter_fsv)
0x1c872: fsv_execute + 0x22 (fitter_fsv)
0xe900: fmain_start + 0x900 (FITTER_FMAIN)
0x41b1: qfit_execute_fit + 0x1bd (comp_qfit_legacy_flow)
0x5384: QFIT_FRAMEWORK::execute + 0x2a0 (comp_qfit_legacy_flow)
0x267f: qfit_legacy_flow_run_legacy_fitter_flow + 0x1c7 (comp_qfit_legacy_flow)
0x14410: TclInvokeStringCommand + 0xf0 (tcl86)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5646: Tcl_EvalFile + 0x36 (tcl86)
0x12606: qexe_evaluate_tcl_script + 0x376 (comp_qexe)
0x11864: qexe_do_tcl + 0x334 (comp_qexe)
0x16755: qexe_run_tcl_option + 0x585 (comp_qexe)
0x380c3: qcu_run_tcl_option + 0x1003 (comp_qcu)
0x160aa: qexe_run + 0x39a (comp_qexe)
0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
0x2233: qfit2_main + 0x73 (quartus_fit)
0x12d68: msg_main_thread + 0x18 (CCL_MSG)
0x1454e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x15b00: mem_thread_wrapper + 0x70 (ccl_mem)
0x12631: msg_exe_main + 0xa1 (CCL_MSG)
0x287e: __tmainCRTStartup + 0x10e (quartus_fit)
0x13d1: BaseThreadInitThunk + 0x21 (KERNEL32)
0x154f3: RtlUserThreadStart + 0x33 (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 8.1
OS version: 6.3
Quartus Prime Information
Address bits: 64
Version: 17.0.2
Build: 602
Edition: Lite Edition
--- Quote End ---
You'll need to raise a mysupport ticket to find out the problem.
