17267 Discussions
Quartus II 12.1 Internal Error: Sub-system: ....
To night, I've just install Quartus II version 12.1 and got 2 error for about 2 hours. Actually there were three but I recorded only two.
It happened when I try to resize partition as previous compilation result in floor plan.
Has anyone seen it before or any suggestion ?
The first:
Internal Error: Sub-system: DLOC, File: /quartus/ddb/dloc/dloc_dev_translator.cpp, Line: 438
Atom dev_element does not match dev_element from the atom location GID
Stack Trace:
0x43fb: DLOC_DEV_TRANSLATOR::get_string_from_atom_location + 0xdb (DDB_DLOC)
0x130a6: APEQ_MODEL_MANAGER::insert_node_data + 0x1a6 (ACE_APEQ_MODEL)
0x1477a: APEQ_MODEL_MANAGER::build_node_selection_map + 0x15a (ACE_APEQ_MODEL)
0x1772f: APEQ_NODE_PROPERTY_DOCK_WIDGET::changing_node_prop erty + 0xb2df (ACE_APEQ)
0x17923: APEQ_LITE_WIDGET::construct_apeq_lite_widget + 0x53 (ACE_APEQ)
0x5026f: ace_acvq_create_frame_wnd_exported + 0x2075f (sys_mdb)
0x5050d: ace_acvq_create_frame_wnd_exported + 0x209fd (sys_mdb)
0x1111ec: QMetaObject::activate + 0x35c (QtCore4)
0x376916: QComboBox::initStyleOption + 0x566 (QtGui4)
0x376c49: QComboBox::initStyleOption + 0x899 (QtGui4)
0x377da1: QComboBox::setCurrentIndex + 0x61 (QtGui4)
0x37a0d3: QComboBox::setModelColumn + 0x313 (QtGui4)
0x37bf91: QComboBox::qt_metacall + 0x211 (QtGui4)
0x1544b0: QAbstractItemModel::rowsInserted + 0x40 (QtCore4)
0xf84ca: QAbstractItemModel::endInsertRows + 0x5a (QtCore4)
0x515e15: QStandardItemModel::insertColumn + 0x335 (QtGui4)
0x515ed0: QStandardItem::insertRows + 0x10 (QtGui4)
0x37ace2: QComboBox::insertItems + 0x192 (QtGui4)
0x4e586: ace_acvq_create_frame_wnd_exported + 0x1ea76 (sys_mdb)
0x4e7f1: ace_acvq_create_frame_wnd_exported + 0x1ece1 (sys_mdb)
0x2cd2a: ACVQV_FRAME_WND::connect_signals_to_ctrl_slots + 0x690a (sys_mdb)
0xa1612: ACVQM_OBJECT_TO_CHAR_MAPPING_CLASS::ACVQM_OBJECT_T O_CHAR_MAPPING_CLASS + 0x40842 (ACE_ACVQ_ACVQM)
0x33104: ACVQ_CTRL_IFC_FOR_VIEW::metaObject + 0x10c64 (ACE_ACVQ_ACVQC)
0x1104e: TclEvalObjvInternal + 0x32e (tcl85)
0x596af: TclExecuteByteCode + 0xf9f (tcl85)
0xa7e53: TclObjInterpProcCore + 0x73 (tcl85)
0x11f2b: TclEvalEx + 0x88b (tcl85)
0x126a9: Tcl_Eval + 0x29 (tcl85)
0x6d60: atcl_tcl_eval + 0x100 (ccl_atcl)
0x1e164: Acvq_Unload + 0x18c74 (ACE_ACVQ_ACVQC)
0xf607: TclInvokeStringCommand + 0xc7 (tcl85)
0x68fe9: ace_acvq_create_frame_wnd_exported + 0x394d9 (sys_mdb)
0x69dfe: ace_acvq_create_frame_wnd_exported + 0x3a2ee (sys_mdb)
0x494809: QAbstractItemView::qt_metacall + 0x229 (QtGui4)
0x4d28c0: QTreeView::qt_metacall + 0x20 (QtGui4)
0x3e021: AFCQ_TREE_VIEW::qt_metacall + 0x21 (GCL_AFCQ)
0x367c1: RPWQ_REPORT_TOC_VIEW::qt_metacall + 0x21 (resr_rpwq)
0x69ec1: ace_acvq_create_frame_wnd_exported + 0x3a3b1 (sys_mdb)
0x4dc0bd: QItemSelectionModel::emitSelectionChanged + 0x69d (QtGui4)
0x4de426: QItemSelectionModel::select + 0x3e6 (QtGui4)
0x4cef57: QTreeView::rowHeight + 0x1907 (QtGui4)
0x4cf996: QTreeView::setSelection + 0x3c6 (QtGui4)
0x492be1: QAbstractItemView::mousePressEvent + 0x461 (QtGui4)
0x4d19ce: QTreeView::mousePressEvent + 0x6e (QtGui4)
0x6cd46: QWidget::event + 0xb6 (QtGui4)
0x39e896: QFrame::event + 0x36 (QtGui4)
0x4926ae: QAbstractItemView::viewportEvent + 0x5ce (QtGui4)
0xfc622: QCoreApplicationPrivate::sendThroughObjectEventFil ters + 0x82 (QtCore4)
0x2008d: QApplicationPrivate::notify_helper + 0xed (QtGui4)
0x22182: QApplication::notify + 0x7e2 (QtGui4)
0xfc4b0: QCoreApplication::notifyInternal + 0x70 (QtCore4)
0x21602: QApplicationPrivate::sendMouseEvent + 0x1e2 (QtGui4)
0x84215: QApplication::winFocus + 0xe25 (QtGui4)
0x86f25: QApplication::restoreOverrideCursor + 0xbe5 (QtGui4)
0x171d: DispatchMessageW + 0x1fd (USER32)
0x14d6: MsgWaitForMultipleObjectsEx + 0x236 (USER32)
0x123eb4: QEventDispatcherWin32:: ProcessEvents + 0x544 (QtCore4)
0x86294: QApplicationPrivate::translateTouchEvent + 0x824 (QtGui4)
0xfbab0: QEventLoop::exec + 0x150 (QtCore4)
0xffedf: QCoreApplication::exec + 0xdf (QtCore4)
0x4e88: msg_exe_fini + 0x58 (CCL_MSG)
0x56cc: msg_exe_fini + 0x89c (CCL_MSG)
0x1614: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x1a4 (ccl_mem)
0x62ff: msg_exe_main + 0x8f (CCL_MSG)
0x167d: BaseThreadInitThunk + 0x19 (KERNEL32)
0x1c3f0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Quartus II 64-Bit Version 12.1 Build 243 01/31/2013 SJ Full Version
Service Pack Installed: 1
__________________________________________________ ____________________________________
And the second:
Internal Error: Sub-system: LLWQ, File: /quartus/prj/llwq/llwq_properties_statistics_tab_widget.cpp, Line: 382
region != NULL
Stack Trace:
0x3704b: LLWQ_REGION_PROPERTY_SHEET::set_region_name_list + 0x1393b (prj_llwq)
0x38abe: LLWQ_REGION_PROPERTY_SHEET::set_region_name_list + 0x153ae (prj_llwq)
0x369d3: LLWQ_REGION_PROPERTY_SHEET::set_region_name_list + 0x132c3 (prj_llwq)
0x6d2ac: QWidget::event + 0x61c (QtGui4)
0x200a1: QApplicationPrivate::notify_helper + 0x101 (QtGui4)
0x235c4: QApplication::notify + 0x1c24 (QtGui4)
0x70387: QWidgetPrivate::show_helper + 0x207 (QtGui4)
0x70acc: QWidget::setVisible + 0x30c (QtGui4)
0x4ed7c: QStackedLayout::setCurrentIndex + 0x11c (QtGui4)
0x4f1ed: QStackedLayout::takeAt + 0x9d (QtGui4)
0x4176c: QLayout::removeWidget + 0x3c (QtGui4)
0x3fc9c7: QTabWidget::clear + 0x47 (QtGui4)
0x23e97: LLWQ_REGION_PROPERTY_SHEET::set_region_name_list + 0x787 (prj_llwq)
0x246bd: LLWQ_REGION_PROPERTY_SHEET::set_region_name_list + 0xfad (prj_llwq)
0x1160: NTFQ_NOTIFY_TARGET::dispatch_notify_msg + 0x60 (ccl_ntfq)
0x12fa: NTFQ_NOTIFY_TARGET:n_ntfq_notify + 0x3a (ccl_ntfq)
0x1688: NTFQ_NOTIFY_TARGET:n_ntfq_notify + 0x3c8 (ccl_ntfq)
0x34b46: LLU_NODE_MEMBER::get_target + 0x7176 (db_llu)
0x1e92e: ACF_REVISION_MANAGER::broadcast_change_notificatio n + 0x3e (db_acf)
0x1f267: ACF_REVISION_MANAGER::write_unlock + 0x37 (db_acf)
0x19151: ASL_BACK_ANNOTATER::xacto_back_annotate + 0x611 (prj_asl)
0x3f7f4: LLWQ_UTILITY::Perform_region_writeback + 0xab4 (prj_llwq)
0x31ba9: LLWQ_REGION_PROPERTY_SHEET::set_region_name_list + 0xe499 (prj_llwq)
0x5b86d2: QAbstractButton::clicked + 0x32 (QtGui4)
0x35d7de: QButtonGroup::checkedId + 0x18e (QtGui4)
0x35f004: QButtonGroup::setId + 0xc54 (QtGui4)
0x35f299: QAbstractButton::mouseReleaseEvent + 0x59 (QtGui4)
0x6cd5a: QWidget::event + 0xca (QtGui4)
0x123eb4: QEventDispatcherWin32:rocessEvents + 0x544 (QtCore4)
End-trace
