17255 Discussions
rom generating code problem
hiii
i've built my ROM containing data of 384000 i stated the data of 76800 and others to be "ZZ....ZZ"
when i compile the code it takes time
and finally return with this warning
Warning: memo_rom.vhd(76836): (vcom-1074) Non-locally static OTHERS choice is allowed only if it is the only choice of the only association.
the problem is that it got an error message when i start simualtion
Fatal: (vsim-3734) Index value 971456 is out of range 383999 downto 0.# Time: 100 ns Iteration: 2 Process: /......./img_rom/line__76841 File: memo_rom_img.vhd# Fatal error in Architecture behavioral at memo_rom_img.vhd line 76841
Note
what is written on line 76841 is
data_out <= rom_data(conv_integer(addr)) when(en = '1') ;
what should i do..
Niveen..
That is a massive rom. Im not surprised it takes a long time...
You cant set Rom values to be Z. It has to be '0' or '1'. 'Z' can only be covered at the tri state buffers in the pins.
Can you post your rom code?
And the error in simualtion is that your address value is coming as 971456 which is clearly out of range of the ROM. You need to sort your addresses out (ie. you need fewer bits in the address bus). 384000 is not a 2^n. When implemented, it will scale up to 2^19.
what is a massive rom..
my rom contains data of an image's pixels
here is its code
entity memo_rom is
generic (pixel : integer := 9 ; img_width_cols : integer := 320; img_height_rows : integer := 240; addr_size : integer := 20);
port(clk : in std_logic;
en : in std_logic;
addr : in std_logic_vector(addr_size-1 downto 0);
data_out: out std_logic_vector(pixel-1 downto 0)
end entity;
architecture behavioral of memo_rom is
type ROM_Array is array ((img_width_cols*img_height_rows)-1 downto 0) of std_logic_vector (pixel-1 downto 0);
--image size 240*320 (row*col) pixels
constant rom_data: ROM_Array := (
0 =>"000000000",
1 =>"000000000",
2 =>"000000000",
3 =>"000000000",
4 =>"000010111",
5 =>"010100011",
6 =>"010010001",
76797 =>"000000000",
76798 =>"000000000",
76799 =>"000000000",
OTHERS => "ZZZZZZZZZ"
begin
data_out <= rom_data(conv_integer(addr)) when(en = '1') else "ZZZZZZZZZ";
end behavioral;
i've changed the "ZZ..ZZ" to "00..00" but nothing changed
there is nothing in my code that reaches this value 971456
Thanks alot,
Niveen
Possible issue 1: you still have ZZs in the "others" case. Avoid having Z and bi-directional signals on you design, except on the I/O pins.
Possible issue 2: That code can't be implemented in a RAM block and thus will be implemented into logic elements, which increases time and design. Try to use a design that can be implemented in a RAM block and matches Quartus ROM inference templates.
An alternative I like for such cases is to LPM_ROM block primitive with .HEX files.
You can also use .MIF instead of .HEX. .MIF have a simpler format, but they're not supported by ModelSIm.
rom : lpm_rom
generic map (
LPM_WIDTH => 8,
LPM_WIDTHAD => 14,
LPM_FILE => "rom.hex",
LPM_ADDRESS_CONTROL => "UNREGISTERED",
LPM_OUTDATA => "REGISTERED"
port map(
outclock => Clk,
address => A,
q => D
thanks alot rbugalho..
i've already replaced ZZs by 00s but same problem..
for using LPM_ROM..would you plz declare more
about rom.hex file is a file that contains my memo data in hex or wt??
execuse my lack of knowledge.. as i'm new in the field of zero experience..
thanks,
Niveen
IIRC, for quartus to infer a rom, you need to use synchronous description - you cannot use asynchronous ROM. So the read address needs to be registered/
Tricky,
Yes, you do. I wasn't sure if the constant array + synchronous read gets inferred but I just tested on Quartus 10 and it does.
So, simply replacing the
data_out <= ....
with
process(clk) begin if rising_edge(clk) then if en = '1' then data_out <= rom_data(to_integer(unsigned(addr))); end if; end if; end process;
Niveen,
no, I was talking about an "Intel HEX" file.
http://en.wikipedia.org/wiki/intel_hex
Quartus has a built-in editor which lets you write such a file by hand.
You'll also find a number of tools in the internet to write/convert data into that format.
