17244 Discussions
Quartus II 13.0 caught in infinite loop during compilation [12127]
Hey all,
I'm with one of the many University programs using the Cyclone II DE2 Board. Today, I finished working on a project, and after many rounds of debugging, it seemed like it would finally finish. However, at around 2% compilation, the compilation stops. The log currently says "12127 Elaborating entity "%name%" for the top level hierarchy." Compilation normally takes about three minutes, and this has been running for almost two hours now.
Here's the log:
Info: *******************************************************************Info: Running Quartus II 32-bit Analysis & Synthesis Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Full Version Info: Processing started: Tue Mar 18 16:15:39 2014 Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Full Version Info: Processing started: Tue Mar 18 16:15:39 2014 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off slc3 -c slc3 Info (20030): Parallel compilation is enabled and will use 4 of the 4 processors detected Info (12021): Found 2 design units, including 1 entities, in source file slc3.vhd Info (12022): Found design unit 1: name-Behavioral Info (12023): Found entity 1: name Info (12022): Found design unit 1: name-Behavioral Info (12023): Found entity 1: name Info (12021): Found 2 design units, including 1 entities, in source file mem2io.vhd Info (12022): Found design unit 1: Mem2IO-Behavioral Info (12023): Found entity 1: Mem2IO Info (12022): Found design unit 1: Mem2IO-Behavioral Info (12023): Found entity 1: Mem2IO Info (12021): Found 2 design units, including 1 entities, in source file cpu.vhd Info (12022): Found design unit 1: CPU-Behavioral Info (12023): Found entity 1: CPU Info (12022): Found design unit 1: CPU-Behavioral Info (12023): Found entity 1: CPU Info (12021): Found 2 design units, including 1 entities, in source file isdu.vhd Info (12022): Found design unit 1: ISDU-Behavioral Info (12023): Found entity 1: ISDU Info (12022): Found design unit 1: ISDU-Behavioral Info (12023): Found entity 1: ISDU Info (12021): Found 2 design units, including 1 entities, in source file reg_16.vhd Info (12022): Found design unit 1: reg_16-Behavioral Info (12023): Found entity 1: reg_16 Info (12022): Found design unit 1: reg_16-Behavioral Info (12023): Found entity 1: reg_16 Info (12021): Found 2 design units, including 1 entities, in source file hexdriver.vhd Info (12022): Found design unit 1: HexDriver-Behavioral Info (12023): Found entity 1: HexDriver Info (12022): Found design unit 1: HexDriver-Behavioral Info (12023): Found entity 1: HexDriver Info (12021): Found 2 design units, including 1 entities, in source file four_to_one.vhd Info (12022): Found design unit 1: four_to_one-Behavioral Info (12023): Found entity 1: four_to_one Info (12022): Found design unit 1: four_to_one-Behavioral Info (12023): Found entity 1: four_to_one Info (12021): Found 2 design units, including 1 entities, in source file tri_state.vhd Info (12022): Found design unit 1: tri_state-Behavioral Info (12023): Found entity 1: tri_state Info (12022): Found design unit 1: tri_state-Behavioral Info (12023): Found entity 1: tri_state Info (12021): Found 2 design units, including 1 entities, in source file bus_mux.vhd Info (12022): Found design unit 1: bus_mux-Behavioral Info (12023): Found entity 1: bus_mux Info (12022): Found design unit 1: bus_mux-Behavioral Info (12023): Found entity 1: bus_mux Info (12127): Elaborating entity "slc3" for the top level hierarchy
Any ideas on how to fix this? I compiled and ran in ModelSim just fine, but unfortunately ModelSim can't blast the program to my board.
I hope you've sorted this by now...?
There's not much in the log to identify any problem. Is this repeatable? You don't say what platform you're running on. However, if you kill off this process (and possibly restart your machine) does it do this every time? Is it repeatable?
Alex
