17268 Discussions
"gating" one process from another
I am brand new to Verilog. I need to produce a specific bit stream output. The bit time is 0.5us so I have an Always block that executes every 0.5us and creates this bit stream. That is working ok. The problem is that the bit stream is continuous, back to back output. I need to gate it at a low frequency like 10Hz.
I tried creating another Always block that executes every 100ms and set/clears a flag that the Other Always block would read/clear. This does not work as variables cannot be operated on by separate Always blocks.
I am sure there is a fundamental solution, I just don't know the fundamentals. ;-)
Rich
Assuming you're operating from a single clock source, you could implement all of this in a single always block. However, there's nothing wrong with splitting logic up across more than one. This often helps readability.
You can gate the output from block 1 with the control signal you're generating in block 2. A combinatorial statement should do the trick. This could reside in 3rd always block.
Perhaps:
always @ (*) if (stream_active) // Control signal from always block 2, active every 100ms output_stream = stream_source; // Whilst active, drive the output signal with the stream else output_stream = 0; // Otherwise, turn it off
Alex
