Hi All,
I've posted about internal errors before, but now I am getting a different one. The code was compiling without issue until I changed an "if" condition to use a different register within the module, and now the code won't compile and generates the following error at 92% of the way through fitting. If anyone has any knowledge as to why this might be please let me know. Is re-installing the Quartus II software my only option, or is there something specific my code may be doing that could cause this? (Code snippet is also below) Thanks for any help! Variable definition (the first in input from a different module, the second is an output from a FIFO constructed within the module); input FIFO_Read_Rq; . . . wire FIRFIFO_Rd_Empty; Culpable IF statement (the first condition compiles fine, the second - shown here active, does not compile at all; if(/*FIFO_Read_Rq == 1'b1 && */FIRFIFO_Rd_Empty == 1'b0) begin Out_Data[15:0] = PD_Data[15:0]; end Internal Error Message; Internal Error: Sub-system: HDB, File: /quartus/h/qtl_object_cache_sys.h, Line: 711 slice->m_locks == 0 Stack Trace: 0x959a0: HDB_ENUM_OPTION::get_value + 0x282a0 0x47e96: HDB_ACTION_PT_INSTANCE::find_design_unit + 0x4f6 0x2117: HDB_FILE_DEPENDENCIES::~HDB_FILE_DEPENDENCIES + 0x1d7 0x1fa3: HDB_FILE_DEPENDENCIES::~HDB_FILE_DEPENDENCIES + 0x63 0x40bb0: HDB_ACTION_PT_INSTANCE::~HDB_ACTION_PT_INSTANCE + 0x250 0x57a5c: HDB_CHIP::reset_visited_flag + 0x33c 0x5db48: HDB_CMP_ACTION_PT_INSTANCE::sweep_timegroups + 0xe8 0x5db6d: HDB_CMP_ACTION_PT_INSTANCE::sweep_timegroups + 0x10d 0x54a87: HDB_CMP_ACTION_PT_INSTANCE::close_pdb_and_clear_cache + 0x127 0x2cbb: HUT_UTIL::restore_cap_inst_from_pdb + 0xfb 0xa736: CSYN_EXPERT:: operator= + 0x89a6 0x45fe4: CSYN_ENV::restore_state + 0x104 0x2751: FSYN_ENV::restore_state + 0x31 0x11acb: CSYN_EXPERT:: operator= + 0xfd3b 0x6a1f: CSYN_EXPERT:: operator= + 0x4c8f 0x4d4b6: CSYN_EXPERT::run_single_algorithm + 0x296 0x4c340: CSYN_EXPERT::run_flow + 0xd0 0x4b891: CSYN_EXPERT::late_fsyn_flow + 0x291 0x48e5a: CSYN_EXPERT::do_physical_synthesis + 0x68a 0x5b888e: VPR_QI_FACADE::vpr_qi_fsyn_fus_init_chle_lib_api + 0xfd41e 0x2c9ad9: VPR_QI_FACADE::~VPR_QI_FACADE + 0xdad19 0x1c5cf9: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x1b05a9 0x1b80fd: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x1a29ad 0x19b275: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x185b25 0x1a2b8d: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x18d43d 0x1c5d5b: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x1b060b 0x1db717: VPR_QI_FACADE::vpr_qi_main + 0x27 0x2de91: fitapi_run_vpr + 0x71 0x46e18: FITCC_EXPERT::run_vpr + 0x138 0x48c0f: FITCC_EXPERT:: place_and_route + 0x14f 0x4aff1: FITCC_EXPERT::invoke_fitter + 0x711 0x4798: fcuda_execute + 0x1f8 0xbab9: fmain_start + 0x7f9 0x1525: Legacy_fitter_Init + 0x4b5 0x2618: Legacy_fitter_Init + 0x15a8 0x2168: Legacy_fitter_Init + 0x10f8 0xf8a6: TclInvokeStringCommand + 0xc6 0x112a8: TclEvalObjvInternal + 0x328 0x121b5: TclEvalEx + 0x8d5 0x12d48: TclEvalObjEx + 0x2d8 0x1abbd: Tcl_EvalObjCmd + 0xfd 0x112a8: TclEvalObjvInternal + 0x328 0x56917: TclExecuteByteCode + 0xe47 0xa2376: TclObjInterpProcCore + 0x76 0x112a8: TclEvalObjvInternal + 0x328 0x56917: TclExecuteByteCode + 0xe47 0xa2376: TclObjInterpProcCore + 0x76 0x112a8: TclEvalObjvInternal + 0x328 0x121b5: TclEvalEx + 0x8d5 0x7c117: Tcl_FSEvalFileEx + 0x1d7 0x7a626: Tcl_EvalFile + 0x36 0xc1ff: qexe_ipc_progress_bar_name + 0x12bf 0x11dd6: qexe_get_command_line + 0x1556 0x150d5: qexe_run_tcl_option + 0x585 0x1e03d: qcu_run_tcl_option + 0xb8d 0x156ed: qexe_process_cmdline_arguments + 0x54d 0x15851: qexe_standard_main + 0xa1 0xa7f8: msg_exe_fini + 0x58 0xaf3c: msg_exe_fini + 0x79c 0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194 0xb8bf: msg_exe_main + 0x8f 0x1841: BaseThreadInitThunk + 0x19 0x57508: RtlUserThreadStart + 0x20 End-trace Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Full VersionLink Copied
Internal errors are usually deterministic and re-installing Quartus won't help. The fact that it occurs in the fitter doesn't help, because your code makes it through synthesis and generates something that is passed to the fitter, so there is nothing "wrong" with your HDL. What are the fitter messages around it? Maybe you can see what's occurring and maybe there's a way to get around it. For example, if Physical Synthesis is occurring, maybe you could turn it off. What happens if you try a different seed?
