17241 Discussions
Quartus II Ripping Out Logic
I'm trying to understand why Quartus is ripping out my logic. I'm trying to implement a microprocessor bus interface to an ARM based part, and I kept getting notes about being unable to find my clock pins. As I dug into it, I found it was saying that my clock input wasn't driving any logic. I've stripped everything out and have it down to a dummy piece of RTL and I'm still seeing my clock ripped out.
library ieee;use ieee.std_logic_1164.all; entity dummy is port ( fpga_clk : in std_logic; fpga_rst : in std_logic; fpga_led_tp : out std_logic_vector(5 downto 0) ); end entity dummy; library ieee; use ieee.numeric_std.all; architecture rtl of dummy is signal sysrst : std_logic; signal sysrstn : std_logic; signal reset_count : integer range 0 to 20; begin rst_con : process(fpga_clk) begin if ( rising_edge(fpga_clk) ) then if ( fpga_rst = '0' ) then sysrst <= '1'; reset_count <= 0; else if ( reset_count < 20 ) then reset_count <= reset_count + 1; else sysrst <= '1'; end if; end if; end if; end process rst_con; sysrstn <= not(sysrst); fpga_led_tp <= (others => sysrstn); end architecture rtl;
And the RTL viewer shows the clock and all the logic as expected (see the attachment--I can't seem to get Chrome to properly operate with an embedded image).
But when I run the compilation, I end up seeing:Info (12127): Elaborating entity "dummy" for the top level hierarchy
Warning (13024): Output pins are stuck at VCC or GND
Warning (13410): Pin "fpga_led_tp[0]" is stuck at GND
Warning (13410): Pin "fpga_led_tp[1]" is stuck at GND
Warning (13410): Pin "fpga_led_tp[2]" is stuck at GND
Warning (13410): Pin "fpga_led_tp[3]" is stuck at GND
Warning (13410): Pin "fpga_led_tp[4]" is stuck at GND
Warning (13410): Pin "fpga_led_tp[5]" is stuck at GND
Info (17049): 5 registers lost all their fanouts during netlist optimizations.
Info (16010): Generating hard_block partition "hard_block:auto_generated_inst"
Info (16011): Adding 0 node(s), including 0 DDIO, 0 PLL, 0 transceiver and 0 LCELL
Warning (21074): Design contains 2 input pin(s) that do not drive logic
Warning (15610): No output dependent on input pin "fpga_rst"
Warning (15610): No output dependent on input pin "fpga_clk"
Which doesn't make any sense at all. Clearly fpga_led_tp is NOT driven by a constant, and fpga_rst and fpga_clk ARE driving logic!
Any idea what is going on?
Attached is the full log file.
(Edit: I'm using "Quartus II 64-Bit Version 14.0.2 Build 209 9/17/2014 SJ Full Version" on Kubuntu 14.04)
The synthesis tool correctly determines that sysrst is only ever '1', so removes the redundant logic.
I suspect you really want the second version to go to '0' :)
If you had first simulated your design in Modelsim, you would not need to ask such a question ... hint hint :)
Cheers,
Dave
Doh!
A simple oversight. Ack!
Sometimes you just need a second set of eyes....
