Quartus II crashes
Hi
I have Quartus II 11.1 sp1. When I open this and click on New Project Wizard, it crashes. No errors no problems and no explanations (as far as I can see).
What should I do. I would download the software again but its several gb so I thought I'd post here first.
unfortunately trying a reinstall is going to be the first step
if you are using the web-based tool, configure it so it doesn't delete the install files after it finishes so you can try another reinstall if necessary
Hi, I finally reinstalled and it fixed the problem. Thanks
