17268 Discussions
Quartus II internal error
Hi All:
We are getting the following error when targeting a Cyclone III device:
*** Fatal Error: Access Violation at 0X0BEC2CD5
Module: quartus_fit.exe
Processors in use: 2
Stack Trace:
0x182CD5 : VPR_QI_FACADE::operator= + 0x181C85 (fitter_vpr20kmain)
0x1825B2 : VPR_QI_FACADE::operator= + 0x181562 (fitter_vpr20kmain)
0x24827B : VPR_QI_FACADE::vpr_qi_main + 0x403B (fitter_vpr20kmain)
End-trace
Quartus II Version 9.0 Build 184 04/29/2009 SJ Full Version
Service Pack Installed: 1
please help, thanks
--- Quote Start ---
Hi All:
Stack Trace:
End-trace
please help, thanks
--- Quote End ---
there is a SP2 available for Ouartus 9.0. Maybe that solves your problem.
Is it the first time you try to map your design on the FPGA ?
Kind regards
GPK
thanks for your reply,
with small designs , i don't have this problem , but when i start to compile a bigger designs this kind of Quartus II internal error come out.
the full compilation pass but after 5 or 6 attempts. so a compilation of 15 minutes takes more than 1 hour.
i tried to install SP2 but when i execute the install nothing happen , though i downloads the SP2 install from altera web site.
--- Quote Start ---
--- Quote End ---
you said "the full compilation pass but after 5 or 6 attempts" does that mean that the error doesn't occur in every run ?
Only to sort out where the problem comes from, can you choose a large e.g StratixIII device and try again ?
Kind regards
GPK
yes the error doesn't occur in every run. same problem for stratix III (in cyclone III i use only 8k of 3c120), i think it s a problem of RAM( i have 2 ram 512 and 1 1 G) or processor (Pentium D ). have you any idea of the system requirement when we target 3c120 and Quartus II 9.0
According to
quartus ii software device support release notes (http://www.altera.com/literature/rn/rn_qts_90sp2_dev_support.pdf
the EP3C120 needs 1,5GB for 32Bit OS
The Pentium D is not the problem, depending on your compile speed requirements
could you check that there is no " " space in your project directory like "c:\my Folder\"
there is no space in the project directory.
my ram config meet , i don't know where the problem.
Create a service request to Altera about this problem:
https://mysupport.altera.com/eservice/login.asp (https://mysupport.altera.com/eservice/login.asp)
--- Quote Start ---
--- Quote End ---
can you run your project on a second PC ? In the past I had a similar problem and it turns out that the memory of the PC was the problem.
Kind regards
GPK
