17268 Discussions
Quartus II internal error
After a syntesis I found an message window :"Quartus II internal error". An image is attached...
Do you know what is the problem???
Not really, only Altera can find out where the problem is comming from. You can try and delete the db and incremental_db folders in your project and recompile it.
