Hi All:
We are getting the following error when targeting a Cyclone III device: *** Fatal Error: Access Violation at 0X0BEC2CD5 Module: quartus_fit.exe Processors in use: 2 Stack Trace: 0x182CD5 : VPR_QI_FACADE::operator= + 0x181C85 (fitter_vpr20kmain) 0x1825B2 : VPR_QI_FACADE::operator= + 0x181562 (fitter_vpr20kmain) 0x24827B : VPR_QI_FACADE::vpr_qi_main + 0x403B (fitter_vpr20kmain) End-trace Quartus II Version 9.0 Build 184 04/29/2009 SJ Full Version Service Pack Installed: 1 please help, thanksLink Copied
--- Quote Start --- Hi All: We are getting the following error when targeting a Cyclone III device: *** Fatal Error: Access Violation at 0X0BEC2CD5 Module: quartus_fit.exe Processors in use: 2 Stack Trace: 0x182CD5 : VPR_QI_FACADE::operator= + 0x181C85 (fitter_vpr20kmain) 0x1825B2 : VPR_QI_FACADE::operator= + 0x181562 (fitter_vpr20kmain) 0x24827B : VPR_QI_FACADE::vpr_qi_main + 0x403B (fitter_vpr20kmain) End-trace Quartus II Version 9.0 Build 184 04/29/2009 SJ Full Version Service Pack Installed: 1 please help, thanks --- Quote End --- Hi, there is a SP2 available for Ouartus 9.0. Maybe that solves your problem. Is it the first time you try to map your design on the FPGA ? Kind regards GPK
thanks for your reply,
with small designs , i don't have this problem , but when i start to compile a bigger designs this kind of Quartus II internal error come out. the full compilation pass but after 5 or 6 attempts. so a compilation of 15 minutes takes more than 1 hour. i tried to install SP2 but when i execute the install nothing happen , though i downloads the SP2 install from altera web site.- Mark as New
--- Quote Start --- thanks for your reply, with small designs , i don't have this problem , but when i start to compile a bigger designs this kind of Quartus II internal error come out. the full compilation pass but after 5 or 6 attempts. so a compilation of 15 minutes takes more than 1 hour. i tried to install SP2 but when i execute the install nothing happen , though i downloads the SP2 install from altera web site. --- Quote End --- Hi, you said "the full compilation pass but after 5 or 6 attempts" does that mean that the error doesn't occur in every run ? Only to sort out where the problem comes from, can you choose a large e.g StratixIII device and try again ? Kind regards GPK
yes the error doesn't occur in every run. same problem for stratix III (in cyclone III i use only 8k of 3c120), i think it s a problem of RAM( i have 2 ram 512 and 1 1 G) or processor (Pentium D ). have you any idea of the system requirement when we target 3c120 and Quartus II 9.0
According to
quartus ii software device support release notes (http://www.altera.com/literature/rn/rn_qts_90sp2_dev_support.pdf) the EP3C120 needs 1,5GB for 32Bit OS The Pentium D is not the problem, depending on your compile speed requirements could you check that there is no " " space in your project directory like "c:\my Folder\"- Mark as New
there is no space in the project directory.
my ram config meet , i don't know where the problem.- Mark as New
Create a service request to Altera about this problem:
https://mysupport.altera.com/eservice/login.asp (https://mysupport.altera.com/eservice/login.asp)- Mark as New
--- Quote Start --- there is no space in the project directory. my ram config meet , i don't know where the problem. --- Quote End --- Hi, can you run your project on a second PC ? In the past I had a similar problem and it turns out that the memory of the PC was the problem. Kind regards GPK
