Hello everybody!
I'm Eduardo, from Venezuela. I'm an EE student and I'm new to this forum :) I have what you may call a noob's question, but I can't get Quartus II to reduce the size of the synthesized gate-logic circuit. I know that the function I'm implementing (a simple boolean function) can be reduced at gate level, but when I click on "RTL Viewer" on Tools, there is actually no simplification :/ And I have tried almost anything to achieve it, but still no success. This is what I get on the RTL Viewer: http://www.alteraforum.com/forum/attachment.php?attachmentid=11172&stc=1 What I should get (took from textbook) http://www.alteraforum.com/forum/attachment.php?attachmentid=11171&stc=1 I performed a wave vectors simulation of both the code I used and the code they use in the textbook and they match, so the code is not the problem. I really hope you can help me and later I can help you too as long as I keep learning :) Thanks in advance! =)Link Copied
The RTL Viewer will show you basically what you coded. It's the map view that will show you the reduced circuit.
Thanks for answering, Tricky, but all I can see is a "black box" with input and output pins on the Technology Map Viewer :/
PD: I accidentally deleted the original post when trying to remove an unused thumbnail xD sorry.- Mark as New
You won't get the "optimized" version anyway because an FPGA doesn't use gates internally, it uses look-up-tables. Your logic can be synthesized in a single LUT cell and that is probably what the technology map viewer is showing you.
Oh, thanks a lot Daixiwen, I understand now :D
