17255 Discussions
VHDL2008 matching equality operator
i can't get VHDL-2008 matching equality operator compiled on quartus2.
when i compile the code below it says:
Error (10327): VHDL error at test.vhd(13): can't determine definition of operator ""?="" -- found 0 possible definitions
'VHDL 2008' option is being chosen on Assignments > Settings > Complier Settings > VHDL input setting .
wondering what i have done wrong. any suggestions? thanks.
code:library ieee;
use ieee.std_logic_1164.all;
entity test is
port(
a,b: in std_logic_vector(3 downto 0);
y: out std_logic_vector
end test;
architecture rtl of test is
begin
y <= a ?= b;
end rtl;
quartus2 version : Quartus II 64-Bit Version 15.0.0 Build 145 04/22/2015 SJ Web Edition
My understanding is that the type ?= returns is the smallest element from the comparation. so in this case std_logic. You try to assign this to a vector. I could be wrong, but does changing the type of y work?
[edit]Reread the specs, it returns ulogic[/edit]
y need to be a std_logic, not a std_logic_vector.
?= returns a single bit.
If it has to be a vector, maybe try:
y(0) <= a ?= b;
Thanks for the replies!
Actually what I did at the first place was declaring y as std_logic, but seems it somehow got messed up when I copied the code to the thread. ('&nbsp' appeared as burried backspaces in the source file? I don't know).
I also had tried std_ulogic(_vector) but no difference.
I tried the following code just in case but again got the same error message for both y and z(0).
library ieee;
entity meqtest is
port(
a,b: in std_logic_vector(2 downto 0);
y: out std_logic;
z: out std_logic_vector(1 downto 0)
end meqtest;
architecture rtl of meqtest is
begin
y <= a ?= b;
z(0) <= a ?= b;
end rtl;
Thanks again,
It could be the fact that Quartus VHDL 2008 support is far from complete. The matching equality operator is also implicitly used when you use the following code:
a : std_logic; .... if a then
They may mean they only support this form.
Otherwise, raise a support ticket for better 2008 support?
Does the code compile fine in Modelsim?
Hi Tricky,
Tried Modelsim (starter 10.3d) and it turned out it's not happy with the code as well, saying :
Signal "a" is type ieee.std_logic_1164.STD_LOGIC_VECTOR; expecting type ieee.std_logic_1164.STD_LOGIC.
I double checked the the env variable VHDL93 has been chanted to 2008 in modelsim.ini file.
It looks pretty much like what you've said. I'll raise a flag to Altera.
Thanks for your help.
I just compiled your code in Modelsim, and it works just fine. The errors you get pop out if you are compiling in 93 mode.
You can compile each file with a specified VHDL version:
vcom meqtest.vhd -2008
And it compiles just fine.
Just tried as you indicated in Modelsim and got it working. Thanks a lot!
also sent a feedback to altera. hope it's supported in Q2.
