17254 Discussions
Quartus II on linux display problem
hi!
i have been trying to install quartus and got some problems.
at first, i could not install it because of '&' syntax error. then i tried sudo bash ./setup command and got over it. but then nothing showed up except 'If nothing shows up, or you don't have an X display' warning.
By the way, i looked up the forum but could not see the messages because of forbidden server..
any ideas?
Thank you.
Same problem.
same problem :S
help please...
what distribution, Quartus II version, etc. a paste of your command history would be useful too
If you're running this on some version of Ubuntu, the problem lies in that on Debian-based distributions, /bin/sh is a symlink to /bin/dash, which has a slightly different syntax than bash, which is what the installer scripts were written for. To work around this, do the following in a tty window:
sudo rm /bin/sh sudo ln -s /bin/bash /bin/sh
<perform the installation>
and then, optionally:
sudo rm /bin/sh sudo ln -s /bin/dash /bin/sh
Ben
