- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I started using Quartus II v15.0 along with Stratix IV GX development kit. I want to run a sample code - Simple Socket Server on it. I am using niosii_ethernet_standard_4sgx230 (https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-net-std-de.tablet.html)example design . I came to know that the Quartus II v15.0 has different naming or different TSE module than the one in the example design(v12.0). I am not a hardware guy so I did not change it and let it be. My question is: Does this affect BSP if I create it using the given *.sopcinfo (from example design) in any ways? As I see that driver name of triple_speed_ethernet is missing in the BSP editor. (image is attached). Or the BSP does not need any triple_speed_ethernet driver? When I run the Simple Socket Server, it is not able to identify any working interface and therefore does not proceed further to identify MAC address or IP address.Link kopiert
2 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
To avoid compatibility issue, it is recommended for you to use the QII 12.0 in which the design was created. 12.0 and 15.0 are few major release apart and I would expect significant changes which might cause the older design not working as expect.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
For other people struggling with making old design compilation work with newer QII versions, here is the link:
https://cloud.altera.com/devstore/platform/15.0.0/nios-ii-simple-socket-server-ethernet-example/
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
