17267 Discussions
Quartus II v7.0 in linux missing 30 days trial
Just installed newly updated Quartus II, upon openning, there are no old three licensing options.
It's my problem or the trail updated to new way?
Have you used the free 30 day trial in the past? I believe if you've used it once, it will not allow you to try it again, even if you install a newer version of Quartus II. If you have a windows machine, you can install Quartus II web edition, which is free to use.
hope this helps,
I used Quartus II free trail before on the same machine, but that was a sort of time ago. And current installation is on a brand new harddrive.
Unless, the free trail permission is granted over internet, it will not make too much sense for me.
The 30-day free trial is only available on Windows for both subscription and web edition. I guess you'll have to swap your windows hard drive back into your machine.
FPGA King
Appreciate your reply, maybe it's new limit for 7.0.
I had v6.0 on linux enabled 30 days thing.
Anyway, Thanks a lot.
