17120 Discussions
Quartus : Master clock could not be derived
qrive1
I am working on Stratix 10 and Quartus 18.1 pro.
Im using a PLL created with the IP 'IOPLL' in order to create a 40MHz clock from a 320MHz clock input from Si5341 ("pll_40").
Normally, I don't have to define both clocks since they are respectively 'iopll_refclk' and 'iopll_outclk' and so are defined in the ip.
I have another pll, almost the same, which is creating its own clocks constraints without problem ("pll_gen").
So where is the difference and why do I have these error messages :
Warning(332087): The master clock for this clock assignment could not be derived. Clock: ip|iopll_0_n_cnt_clk was not created.
Warning(332035): No clocks found on or feeding the specified source node: ip|iopll_0|stratix10_altera_iopll_i|s10_iopll.fourteennm_pll|refclk[0]
Thanks in advance,
SreekumarR_G_Intel
Can you please attach the design in the forum ? It will helpful to look at more in details
Thank you ,
Sree
qrive1
SreekumarR_G_Intel
Thank you for sharing the files ,
Reason I requested for the file that I assumed you already done the constraint manually and getting the this warning. Hence I am curious to know what is going on :) ..
Anyway I noticed you didnt add constraint ,Can you create .sdc file (Add to the project) and add below commands to it . Once I added , those warning went off
derive_pll_clocks -create_base_clocks
derive_clock_uncertainty
create_clock -period 10.000 -name refclk1 -waveform {0 5} [get_ports {clk_ffly0_ref}]
Also Noticed your top module of VHDL is incomplete . (i.e) VHDL based RTL must add the component port and port mapping of those component .
Attached modified top module file for reference.
Thank you,
Sree
qrive1
I think "derive_pll_clocks" command is obsolete (with quartus 18.1 pro and stratix 10)
But sorry I wasn't clear : It's just about understanding why, not about solving a concrete case.
My question is exactly on why do I have to define the clk_ffly0_ref for the pll_40 and I don't have to do it for the refclk_100 in the pll_gen. It doesn't seem logic to me.
Since all my clocks are part of a PLL, it should not be necessary to declare any clock (I mean create_clock or create generated clock commands).
Thanks in advance
SreekumarR_G_Intel
sorry , caught into other stuff and missed out ,
Actually i am not sure why not for the both the clock, I will raise the quires to the internal team and come back to you .
Meanwhile if you find anything similar can you let me know as well so i can learn from you.
Thank you ,
Sree
