17240 Discussions
Quartus Prime 17.1 with Intel HLS Compiler issues
Hi, I have installed MS Visual Studio 2010 and Quartus Prime 17.1 with Modelsim Intel FPGA Starter Edition 10.5b to my Windows 10 computer. I am trying to run counter example in hls. Here, the output when I run build.bat -test-fpga:
C:\intelFPGA\17.1\hls\examples\counter>build.bat test-fpga i++ -march=StratixV counter.cpp -o test-fpga.exe test-fpga.exe : warning LNK4088: image being generated due to /FORCE option; image may not run Run test-fpga.exe to execute the test.
Then, I try to simulate running test-fpga.exe it just prints "PASSED" nothing happens. What should be the problem?
Counter.cpp have only two printf statement for the pass and fail condition, count values are not displayed.
To see the count values introduce printf statement for seeing the count values at console.
Example: for(unsigned int i=0; i < SIZE; ++i) { if (result != i) { printf("ERROR: Expected %u, found %u\n", i, result); pass = false;} else{ printf("Expected %u, found %u\n", i, result); } }
You can also run test-x86-64.exe to see the result after compilation using command build.bat test-x86-64
https://alteraforum.com/forum/showthread.php?t=57668
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Thank you for your response Anand. However, my point was when I ran the test-fpga.exe should not it start a simulation in modelsim?
--- Quote Start ---
--- Quote End ---
No,
It should be manually done.
Let me know if you need any further assistance.
Anand Raj Shankar
Thank you, Anand. I got it. I think I misunderstood this part of the video: https://youtu.be/nybw9k7knj4?list=pl0pu5hg9ynizjbcomw4a-vsft7jyd1mli&t=1709. Executable tests the component using ModelSim simulator. For simulation results, I need to run verification\vsim.wlf manually.
I am a beginner. I apologize for my ignorance, but could someone explain in detail the procedure to follow in order to simulate the counter in modelsim.
I have compiled the component with:
build test-fpga
and that created the project folder with the 4 subfolders (I have only changed the build.bat to compile for CycloneV)
So now I have the .proj
From here, can someone help me with step-by-step instructions on how to run simulation.
I have tried several ways but with no success.
Thank you
志周1
I also use CyconeV. Do you meet the LNK4088 waring?​
--- Quote Start ---
build test-fpga
Thank you
--- Quote End ---
Can anyone help?
--- Quote Start ---
Can anyone help?
--- Quote End ---
Can you please open new Thread/Case.
Because present thread title and question you asked does not match, which will not help forum user.
Anand Raj Shankar
In build.bat file you need to add -gvhdl as a compiler option to i++.
So it should be look like
i++ -march="fpgafamily" -gvhdl counter.cpp -o test-fpga.exe
Then build test-fpga and run test-fpga.exe. This will create a simulation file under verification folder.
Finally, open the verification\vsim.wlf file with Modelsim.
--- Quote Start ---
--- Quote End ---
I have encountered an error when I did this. I have opened a new thread for this problem here: https://www.alteraforum.com/forum/showthread.php?t=58394&p=237529#post237529
Please post your comments there.
I want to make this counter on the 7 segment display of DE1 SoC board, my question is: How can I do this with intel HLS ??
Thank you
Sarah
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
Thank you
Sarah
hi,
how to make counter on 7 segment display de1 soc with c++ program for intel hls??
thanks for replying,
best regards
