17256 Discussions
Quartus Prime Lite 19.1 Error Message when doing run simulation for Waveform
Gab3
I am trying to put a project together and when I design my logic circuit and compile, it is successful. When I create a University WVF file, and try to do run simulation it give me an error that the file does not exist. Are there any solutions for this?
TingJiangT_Intel
Hello, can you post the screenshot and copy the entire error message here.
Gab3
TingJiangT_Intel
I've found a solution. When you click "Run Functional Simulation" again, a window will prompt you to save the .vwf simulation file. Please use the default path and file name (do not modify it yourself) during the saving process, and this should resolve the error.
Gab3
Today, my waveform simulation worked. I don't know what I did different but here are some screenshots attached.
WZ2
Hi there,
Glad to know that please let us know if any updates or issues.
TingJiangT_Intel
Hi there, if there is no more questions. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
