17241 讨论
Quartus Prime Lite OpenCL Licensing
名誉分销商 II
3,659 次查看
The link below says that the OpenCL SDK is available on the free Quartus Prime Lite Edition, but that it requires an additional license:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/po/ss-quartus-comparison.pdf
How do I get this license? Is it also free or do I need to buy a specific license for OpenCL?
0 项奖励
9 回复数
名誉分销商 II
2,359 次查看
Hi, you will need to pay for the license for OpenCL SDK, but once you do that you can use it with Quartus Prime Lite (hence, you don't have to make a second purchase of Quartus Prime Standard/Pro, unless you are using devices that are not supported in Quartus Lite).
I would encourage that you try asking for a trial license (perhaps file a service ticket to Altera?) for evaluation.
0 项奖励
名誉分销商 II
2,359 次查看
--- Quote Start ---
--- Quote End ---
Thanks for the response. Regarding installation, if the OpenCL SDK only comes with Standard or Pro editions (see OpenCL package), and Lite Edition apparently does not come with OpenCL (couldn't find it), how do I make the combo Lite + OpenCL work?
0 项奖励
名誉分销商 II
2,359 次查看
Good point. I suspect that the Lite Edition is only meant for Cyclone V devices since it is the only valid combo (OpenCL + Lite). I think it is best to check with Altera on the licensing option - I could be wrong here.
0 项奖励
名誉分销商 II
2,359 次查看
--- Quote Start ---
--- Quote End ---
That's exactly my setup: I have a DE0-Nano-SoC based on Cyclone V for learning purposes.
I managed to install Quartus Prime Lite + OpenCL by downloading "Intel FPGA SDK for OpenCL" from the "Individual Files" section on the Quartus Prime Standard edition download page (a 400 MB download).
Now, two problems remain:
- About licensing, when I try to compile a OpenCL kernel:
$ aoc hello_world.cl
Could not acquire a valid license for the Intel(R) FPGA SDK for OpenCL(TM).
I asked Altera support about licensing for this setup. Let's see what they say.
- The linux_sd_card_image provided by the OpenCL SDK doesn't boot on the DE0-Nano. I probably will have to create my own OpenCL BSP, since the ones I found online were made for OpenCL 14, and I would like to use 16.1.
I'll update this thread when/if I get these things to work.
0 项奖励
名誉分销商 II
2,359 次查看
Hi there, if I dont understand incorrectly, you managed to install OpenCL 16 into your board. How did you do this? Are the files offered as standalone and you just scp into the board?
0 项奖励
名誉分销商 II
2,359 次查看
--- Quote Start ---
--- Quote End ---
Sorry if my post was misleading: what I managed to do was to install the OpenCL SDK along with Quartus Lite on my PC. I would like to use v16 on the board, but I couldn't find an image for it.
I'm struggling with the licensing right now, but if/when I manage to do this, I'll update the post.
If v14 is OK to you, I found a working DE0-Nano compatible image on http://mail.terasic.com.tw/~david/de0_nano_soc_opencl_bsp.zip.
0 项奖励
名誉分销商 II
2,359 次查看
--- Quote Start ---
--- Quote End ---
Dont be sorry :) not at all. Thanks for your reply. I understand a bit better what I am doing now and I have managed to install the OpenCL RTE version 16 into my board. The issue I have now is that the driver is not compiled and I am not being able to compile it either. I have initiated a thread for that here:
http://www.alteraforum.com/forum/showthread.php?t=53980&referrerid=95000
Would you like me to post here if I get to a solution?
Many thanks!
0 项奖励
名誉分销商 II
2,359 次查看
--- Quote Start ---
--- Quote End ---
Hi there,
Did you manage to resolve your licensing issues? What was the solution for this?
Many thanks!
0 项奖励
名誉分销商 II
2,359 次查看
I just hit a wall with my new AtlasSoC board - exactly the SAME problem. I'm trying to find a OpenCL SDK license to use with Quartus Prime Lite.
Terasic says they can't sell it to me and Altera forwards me to my distributor (Mouser). They have to think about it. Really?
Did anybody find a solution for how to get up and running with the DE0 AtlasSoC board and OpenCL? After all, I DID receive a BSP for that board from Terasic, so it's only the license holding me back...
0 项奖励
回复
