17241 Discussions
Quartus Prime Lite Platform Designer Failed to find module error
CFurr1
Hi I am new to Quartus and FPGAs. I am trying to use the Platform Designer and create a NIOS2 simple system but when I go to generate the HDL I get an error of failed to find module. I have tried different modules like memory, JTAG uart and I get the same error. What am I doing work can anyone point me in the right direction?
MEIYAN_L_Intel
Could you try the Platform Designer Tutorial to generate HDL for Nios II processor in the link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_qsys_intro.pdf
CFurr1
Does the NIOS II need a license to work and the HDL file to generate? I followed a similar tutorial with the same results. The Platform Designer shows no errors until I click the generate HDL button then I get the error of can't find module for the system I am making.
MEIYAN_L_Intel
May I know the information as below:
  1. Quartus Prime edition and version
  2. Os version
CFurr1
I am using the Lite Version 19.1 running on Ubuntu 16.04
MEIYAN_L_Intel
For the Quartus Prime Lite edition is not required license file.
I had try to generate HDL for a system with with step as below:
1. New Project (in Quartus)
2. Open PLatform Designer
3. Connect the system with clock source and Avalon-MM clock crossing bridge
4. Generate HDL
It is successfully generate.
May I have the full error message for further investigate?
CFurr1
[image: Screenshot at 2019-12-31 10:58:26.png] [image: Screenshot at 2019-12-31 10:58:51.png] Here are some screen shots of the Platform Builder. It seems that not matter what module I connect to the NIOS-II CPU it can't find that module. I have tried FIFO's JTAG-UART, PIO, SRAM.... all have the same error of can't find the module. Thanks -Clint
MEIYAN_L_Intel
I am not able to look into the screenshot. Could you try to attach the screenshot again?
CFurr1
MEIYAN_L_Intel
I am still not able to have the zipped attachment as seen in picture below:
You may try to attach the picture as picture below: attachment_2.PNG
CFurr1
This is turning out to be quite difficult lol. I made a Google share folder that has the pictures hope this does the trick. Your attached pictures did not come through as well. https://drive.google.com/drive/folders/12cNfsp18tlmbdomDrPXodR0ke1aM58zq?usp=sharing Thanks
MEIYAN_L_Intel
I have tried this system connection in Quartus Prime Pro 19.3 and the system is not allowed to connect data master to on-chip memory s1 and avalon mm pipeline bridge s0. But in your picture show no error with this connection.
I had reported this issue to the developer.
Also, I had tried to used Quartus Prime Lite v18.1 to connect the system in Platform Designer as well. It does not show the error with failed to find module.
May you try to revert back to Quartus Prime Lite v18.1?
CFurr1
Thanks for all your help. I did try version 18 and it has worked so far without error. Thanks.
MEIYAN_L_Intel
Glad to hear that you have success to generate HDL in Platform Designer.
DDoro
To solve your problem, you need to set the "Create HDL design files for synthesis" to "None" in the generation window in Platform Designer
