17254 Discussions
Quartus Prime + Modelsim not Simulating
FPGA_ALL_DAY
I have two issues related to Quartus Prime simulations. When adding an IP PLL to my project and running a simulation, I get the following error:screenshot.jpg
When I remove the PLL from my code, this error goes away. I have made sure the '.vo' simulation file and all additional files are in the project folder.
My other issue is that whenever I instantiate a module inside another module, when running a simulation the waveform window does not open nor display any testbench info. When I remove a module's instantiation, this issue goes away.
paveetirrasrie_Intel
The error for your first concern maybe due to having space in your project directory pathname. Kindly try change your directory path to not have space and re-run the simulation.
Pavee
Just wanted to check with you, is your concern has been addressed?
If yes , kindly do let me know.
Thank You
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
