17268 Discussions
Quartus Prime Pro : Internal Error: Sub-system: GIO, File: /quartus/edt/gio/gio_gdf_parser.cpp,
MRaiz
I converted the old project from max + plus2 to quartus 7, but since I can change FPGAs to MAX 10, I opened the converted project to Quartus Prime. in Quartus Prime during compilation issued a bug. Everywhere compiled. How to solve a problem ?
Problem Details
Error:
/quartus/edt/gio/gio_gdf_parser.cpp, Line: 4611
m_file_db->add(new_text)
Stack Trace:
  0x23b54: GIO_GDF_PARSER::add_connector_graph + 0x504 (EDT_GIO)
  0x54ce4: GIO_GDF_PARSER::parse_graphic_file + 0xb4 (EDT_GIO)
  0x52540: GIO_FILE_DB::open_and_parse_file + 0x90 (EDT_GIO)
  0x47075: GDFX_ELABORATOR::elaborate + 0x1b5 (SYNTH_GDFX)
  0xda8ef: SGN_FN_LIB::elaborate + 0x24f (synth_sgn)
  0xe330f: SGN_FN_LIB::start_gdf_flow + 0xf (synth_sgn)
  0xe1b22: SGN_FN_LIB::start + 0xa42 (synth_sgn)
  0xc294a: SGN_EXTRACTOR::single_module_extraction + 0x15a (synth_sgn)
  0xb7524: SGN_EXTRACTOR::recursive_extraction + 0x204 (synth_sgn)
  0xb6e6f: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist + 0x36f (synth_sgn)
  0xb757b: SGN_EXTRACTOR::recursive_extraction + 0x25b (synth_sgn)
  0xb0913: SGN_EXTRACTOR::extract + 0x1d3 (synth_sgn)
  0x1309e: sgn_qic_full + 0x19e (synth_sgn)
   0x4391: qsyn_execute_sgn + 0x131 (quartus_map)
  0x13fac: QSYN_FRAMEWORK::execute_core + 0x12c (quartus_map)
  0x13ab6: QSYN_FRAMEWORK::execute + 0x496 (quartus_map)
  0x112bc: qexe_do_normal + 0x1ec (comp_qexe)
  0x16142: qexe_run + 0x432 (comp_qexe)
  0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
  0x1b06b: qsyn_main + 0x51b (quartus_map)
  0x13328: msg_main_thread + 0x18 (CCL_MSG)
  0x14b0e: msg_thread_wrapper + 0x6e (CCL_MSG)
  0x15b00: mem_thread_wrapper + 0x70 (ccl_mem)
  0x12a11: msg_exe_main + 0xa1 (CCL_MSG)
  0x29862: __tmainCRTStartup + 0x10e (quartus_map)
  0x13033: BaseThreadInitThunk + 0x13 (KERNEL32)
  0x71460: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_map
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
KhaiChein_Y_Intel
Can you compile in the latest version of the Intel Quartus Prime software, which is v18.1, instead of version 7?
MRaiz
@KYeoh
Hi
I will try but it seems to me that I need to understand the essence of the problem.
KhaiChein_Y_Intel
A design/project is required for Internal Error debug. Could you compile your design in the latest version of the Intel Quartus Prime software and see if the problem persists? If yes, you may attach a small, non confidential test case that can reproduce the error for investigation.
Please be informed that there should be no confidential information disclosed in the forum. Kindly contact your FAE/Intel sales representative to submit a service request to Intel Support team if you would like to provide a confidential design for investigation.
MRaiz
@KYeoh
Hi
I was able to successfully compile the project in the latest version of program.
Thanks for the help.
KhaiChein_Y_Intel
Hi Mraiz,
It's glad to hear that.
May I know which exact version you are using? I believe your reply would be beneficial to more users.
MRaiz
Hi KYeoh
Started using Quartus Prime 18.0 Standard Edition.
