17241 Discussions
Quartus Prime Unexpectedly Quit
SrLam9
I am trying to compile a project that I have compiled before in the past (many times). I have tried compiling after deleting the db and incremental db folders, but the error still occurs.
Here is the error log:
Problem Details
Error:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/bsyn_interface/bi_lab.cpp, Line: 148Internal Error
Stack Trace:
0x8a9a91: BI_LAB::remove_atom + 0x71 (fitter_vpr20kmain)
0x8a4081: BI_LABMGR::remove_atom_from_lab + 0x91 (fitter_vpr20kmain)
0x8a3f44: BI_LABMGR::add_atom_to_lab + 0x24 (fitter_vpr20kmain)
0x38aa0: BSYN_AMU::add_atom_to_lab + 0xa0 (fitter_bsyn)
0x84ace: BSYN_SOLN::sync_tdb_graph + 0x11e (fitter_bsyn)
0x83e86: BSYN_SOLN::implement + 0x2d6 (fitter_bsyn)
0x2b94c: BSYN_APPLY::implement + 0x18c (fitter_bsyn)
0x2c91c: BSYN_APPLY::try_solns + 0x7c (fitter_bsyn)
0x26af0: BSYN_APPLY::apply_crit_paths_inner + 0x1d0 (fitter_bsyn)
0x26ced: BSYN_APPLY::apply_crit_paths_outer + 0x7d (fitter_bsyn)
0x26e3d: BSYN_APPLY::apply_domains + 0xdd (fitter_bsyn)
0x26853: BSYN_APPLY::apply_crit_paths + 0x173 (fitter_bsyn)
0x2dfbc: BSYN_DISPATCH::apply_tricks + 0xa7c (fitter_bsyn)
0x2ea7f: BSYN_DISPATCH::run_post_quench + 0x27f (fitter_bsyn)
0x2d29b: BSYN_DISPATCH::Run + 0xfb (fitter_bsyn)
0x2f0e5: BSYN_ALGORITHM_BASE::Execute + 0x25 (fitter_bsyn)
0x2ff8f: BSYN_STRATEGY::Run + 0x4f (fitter_bsyn)
0x2f57a: BSYN::bsyn + 0x10a (fitter_bsyn)
0x2f429: bsyn + 0x89 (fitter_bsyn)
0x89cdd6: bi_run_bsyn + 0x136 (fitter_vpr20kmain)
0x89cfb2: bi_bsyn + 0x42 (fitter_vpr20kmain)
0x574495: VPR_QI_FACADE::bsyn + 0x85 (fitter_vpr20kmain)
0x5741ce: VPR_QI_FACADE::vpr_apl_bsyn_flow + 0x5e (fitter_vpr20kmain)
0x2c766: FDRGN_EXPERT::run_vpr + 0x196 (fitter_fdrgn)
0x2843b: FDRGN_EXPERT::place + 0x3b (fitter_fdrgn)
0x143ab: fit2_fit_place_auto + 0x20b (comp_fit2)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x3c4a: fit2_fit_place + 0x2fa (comp_fit2)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5646: Tcl_EvalFile + 0x36 (tcl86)
0x12606: qexe_evaluate_tcl_script + 0x376 (comp_qexe)
0x11864: qexe_do_tcl + 0x334 (comp_qexe)
0x16755: qexe_run_tcl_option + 0x585 (comp_qexe)
0x380c3: qcu_run_tcl_option + 0x1003 (comp_qcu)
0x160aa: qexe_run + 0x39a (comp_qexe)
0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
0x2233: qfit2_main + 0x73 (quartus_fit)
0x12e98: msg_main_thread + 0x18 (CCL_MSG)
0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
0x12761: msg_exe_main + 0xa1 (CCL_MSG)
0x287e: __tmainCRTStartup + 0x10e (quartus_fit)
0x159cc: BaseThreadInitThunk + 0xc (kernel32)
0x5385c: RtlUserThreadStart + 0x1c (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 7
OS version: 6.1
Quartus Prime Information
Address bits: 64
Version: 18.0.0
Build: 614
Edition: Standard Edition
Thank you
Vicky1
Could you please check whether it`s project specific & operating system specific issue?
  1. If possible try same project on windows 10 with Quartus standard edition
  2. Try to check with different project(D flop with full compilation) on present system
  3. Can you provide the project for replication(Project-> Archive Project..)?
Vicky
Vicky1
May I know any update?
Vicky
SrLam9
Hi Vicky,
Sorry about that.
  1. It is not OS dependent because I also tried to compile the project on Windows 10 as well and received the same error.
  2. I tried with a different project and it compiles properly.
  3. Sorry I cannot provide the project :(
However, I was able to compile after creating a new project with the same files.
Thank you again
Vicky1
"However, I was able to compile after creating a new project with the same files.""-- Do you mean issue is resolved by creating new project using same files?
please let me know, if you have any different concern.
Vicky
SrLam9
Yes that is correct
