Hi
I am trying to run Modelsim-Altera gate level simulation from Tools -> Run simulation Tool -> Gate Level simualtion Every time I try to run, it responds "Rerun the EDA Netlist Writer". When I do re-run the netlist writer and try to re-run the simulation it responds with the same message. I am able to run an RTL simulation runs just fine form the Tools menu. That said, if I try to run RTL or Gate level simulations from the "Task" window, the simulations just hang !!!! Anyone experienced similar issues (that they resolved) FionbarraLink Copied
Hi Fionbarra,
Did you ever figure this out? I have the same issue. Thanks, Stuart- Mark as New
--- Quote Start --- Hi Fionbarra, Did you ever figure this out? I have the same issue. Thanks, Stuart Hi Stuart. I did eventually sort this out with support form Altera support. Really a case of RTFM , but you know how it is ...... I had not included my testbench in the "NativeLink settings" in the "Simulation" Settings window. Let me know how you get on. Fionbarra
