17249 Discussions
Quartus Prime project access permission error
MKS_Alt
I just installed Quartus Prime Lite 2023.1. I am coming across following error
"Can't open project -- you do not have permission to write to all the files or create new files in the project's database directory"
I tried going through the solutions suggested earlier in this forum, but none of them are working.
Creating a new project in some specific location works, but if I copy a different project folder in the same location, it gives this error.
Please suggest if anyone has come across any solution for this.
Thank you
RichardTanSY_Altera
My guess is you are creating a project in a folder directory that need your PC administrator access and the Quartus does not run as administrator.
Create a project in a folder directory that do not require administrator access.
Richard Tan
RichardTanSY_Altera
Dropping a note to ask if my last reply was helpful to you.
Do you need any further assistance from my side?
Richard Tan
Ed1632
I am also having this issue. I am running Quartus Prime 22.1, and have been using it for several months, compiling and programming. I tried moving a project and QP refused to open it, throwing the "you do not have permission to write to all the files" error pasted in below. It now refuses to open any project, including the original.
I have tried running as administrator, I have tried the compatibility check, and I have tried creating a project on a public network drive.
I am able to open the original project on my personal (as opposed to work) computer. Are there any known issues with recent windows updates? I am using Windows 10 Enterprise 19044.4291
I am also concerned about Microsoft One Drive, which creates invalid path names, but as I said I did try on a network drive with a legal path.
Do you have any advice or known resolutions to this issue?
RichardTanSY_Altera
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for reaching out to us!
Richard Tan
Ed1632
I recently had some issues with the same error message- it occurred very suddenly in a project that had previously been fully functional. I have had some success re-creating the project in C:\workspace (the only folder on C I can write to) instead of "Documents".
I could not include any of the files from the Documents folder, I had to create new files and copy:paste the old file contents into them. Luckily it is a fairly small project and it was doable. I don't know why the error started and I am not thrilled with the workaround, but my work is no longer blocked.
sstrell
Quartus does not like network drives or Onedrive.  Everything really should be on a local drive.
Kin_Lato
I have the same exact problem. I havent used OneDrive and doing literally everything that I could find about this problem and still nothing. I can't even open newly made project files so I dont know what else to do.
