17268 Discussions
Quartus Pro programmer fails: "sof is incompatible".
HEass1
I recently installed Quartus Prime Pro 22.2 (using Win 10) and opened a project.  I updated all the IP and re-compiled from the beginning, successfully generating an sof.  There were no errors at this stage.  I tried to program the part and received the following error:
"File xyz.sof is incompatible - xyz.sof is compiled by ACDS 22.2.0, please recompile design using ACDS 22.1 or later."
There seems to be a tool issue - 22.2.0 is the latest and is clearly later than 22.1.
I did find information about  a possible problem with the reset release IP, but the solution was to recompile in a later Quartus version.  Any ideas gratefully received.
Farabi
May I know what IP you try to compile? Do you have license for this IP?
regards,
Farabi
HEass1
I have a simple design, instantiating the reset_release IP, one F-tile 25G NRZ PHY and the F-tile PLL.  I believe I have the correct licenses to use those.
HEass1
After trying a lot of things I finally got the compile and programming to go through.  I'm not 100% sure what fixed it, but I'm guessing that it was either that I manually regenerated (fully) all the IP, or that I removed a setting from the QSF file.  The setting was:
# Global setting
# I saw a note in the F-tile user guide that inappropriately setting this might cause a config error (p52).
# But that might just be if the power/gnd pins are tied off.
#set_global_assignment -name PRESERVE_UNUSED_XCVR_CHANNEL ON
NurAiman_M_Intel
Thanks for sharing your findings. We are glad that you can now move forward with your design. I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
