17256 Discussions
Quartus Web Edition 7.1 Schematic Symbol Error
I created a module in Verilog that I am including in a schematic as a symbol. The module has bus inputs called:
input wire [23:0] ch1,
input wire [23:0] ch10,
input wire [23:0] ch11,
etc. up to ch16
it also has inputs called
input wire ch1_U
input wire ch1_V
I get this error when trying to compile the schematic with the included symbol.
Error: Illegal name "ch119" -- pin name already exists
Error: Illegal name "ch118" -- pin name already exists
Error: Illegal name "ch117" -- pin name already exists
Error: Illegal name "ch116" -- pin name already exists
Error: Illegal name "ch115" -- pin name already exists
Error: Illegal name "ch114" -- pin name already exists
Error: Illegal name "ch113" -- pin name already exists
Error: Illegal name "ch112" -- pin name already exists
Error: Illegal name "ch111" -- pin name already exists
Error: Illegal name "ch110" -- pin name already exists
Error: Illegal name "ch123" -- pin name already exists
Error: Illegal name "ch122" -- pin name already exists
Error: Illegal name "ch121" -- pin name already exists
Error: Illegal name "ch120" -- pin name already exists
This was not a problem when I had only
input wire [23:0] ch1-ch8.
Does Quartus use more than three characters for their pin names? It appears like the ch1 is aliasing with ch10, etc.
Thanks for any help.
RAUL
Nope,
You must think like a computer.
It is doing exactly as you ask.
I will space thinkgs out a little to help you see it better.
ch1 19 looks just like ch11 9
If you rename your inputs to something like;
ch1bit
ch2bit
ch11bit
etc
you will get what you want.
It is always a risk to name a signal with a number if you are going to vectorize it.
Avatar.
Thank you, very good point, I think it is a bug, though.
I wrote a wrapper to my module with the first three characters being different for ch1 and ch11. The Quartus schematic tool is so far the only tool that has had a problem with using ch1[23:0] and ch11[23:0]. ModelSim is OK, even Quartus Verilog Synthesis is OK.
RAUL
