Quartus and Xilinx
Hello all,
A while ago I had read somewhere something that looked like you could compile a xilinx project with Quartus and I see a lot of answers when someone working with ise: use Quartus.
So my question is, is it really possible to use Quartus and make xilinx projects. If so, how do I tell Quartus it should look for the Xilinx files, wherever Xilinx hides them?
Right, I just found a post they don't support each other, but I didn't find it in the search for Xilinx, but underneath my post in similiar threads and its last post was 2010. But than I assume they still don't support?
Greetings,
ZeMoi
--- Quote Start ---
Hello all,
Greetings,
ZeMoi
--- Quote End ---
You are asking for trouble. Altera and Xilinx are at extreme ends of alphabet. Any mixing is a dangerous ****tail and smoke will go up.
Actually in one way I would say you are absolutely right, it can never be of any good to let them compile other vendors FPGA code.
The other way I would say, why can't they have some similiar compiler, I would think they both must do exactly the same thing: read file, make an FPGA design, convert to chip. Or is it the software part that doesnt matter and shouldn't I see it as c code converted to the right os? I really have no idea how I should look at the way FPGA's are configured, I would say with just some zero's and one's and thats it
--- Quote Start ---
--- Quote End ---
I hope the world stayed that simple. The reality is each developed their products their way to make money. The trade secrets are kept tight.
You can convert your design into Quartus equivalent but not directly compile using Quartus. Read this app notes for more information
http://www.altera.com/literature/an/an307.pdf
@kaz
Allright, than thats one less concern to think about. I need to try and automate the compilation process and thought people might only have Quartus and want to compile it with it. Now I can just say; compile it with the Xilinx environment you like, when using Xilinx FPGA and compile it with the Altera vendor you like, when using Altera FPGA's:)
@skyjuice88
I have read a part of that indeed, but I can't do much with that. I don't have a clue what Xilinx tools are doing, whatever they are supposed to do and I do understand the Quartus tool. So I would first figure out how these Xilinx tools work, I actually need the other way around. How to convert my Quartus design to this ISE design, I really can't understand how people work with that tool.
I am a happy Quartus user:) and an unhappy person probably abusing ISE instead of using it.
