17264 Discussions
Quartus assembler crashes at 52% with an access violation
K_Crocker
The attached archive contains a project which consistently crashes during the assembly phase. Help would be greatly appreciated!!
Problem Details
Error:
*** Fatal Error: Access Violation at 00007FF88F426EC4
Module: quartus_asm.exe
Stack Trace:
0x6ec3: CGA_FAMILY_INTERFACE::get_bool_data + 0x13 (atm_cga)
0x2f01c: ASMIO_MIO_OE_INVERT::process_atom + 0x96c (comp_asmio)
0x1d028b: process_cdb + 0xaab (comp_asm)
0x1ca1f5: assemble_bcm_chip + 0x455 (comp_asm)
0x1cba07: assemble_bcm_device + 0x10a7 (comp_asm)
0x1c7b52: asm_assemble + 0x472 (comp_asm)
0x3110: QASM_FRAMEWORK::execute + 0x80 (quartus_asm)
0x11524: qexe_do_normal + 0x1d4 (comp_qexe)
0x16630: qexe_run + 0x3a0 (comp_qexe)
0x17641: qexe_standard_main + 0xc1 (comp_qexe)
0x5aed: qasm_main + 0x7d (quartus_asm)
0x13638: msg_main_thread + 0x18 (CCL_MSG)
0x1494e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x18520: mem_thread_wrapper + 0x70 (ccl_mem)
0x12df1: msg_exe_main + 0xa1 (CCL_MSG)
0x8bd8: __scrt_common_main_seh + 0x11c (quartus_asm)
0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
0x52650: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 21.1.0
Build: 842
Edition: Standard Edition
K_Crocker
***** PROBLEM SOLVED!! *****
Problem was traced to the project using the ALTLVDS_TX macrofunction without setting the output pins to LVDS. In the Terasic Cyclone V GX Starter Kit all LVDS-capable outputs are assigned to be "2.5 V" in the QSF file -- close but not quite there!
It would be nice if this issue was caught before crashing the assembler (say, in the Fitter).
ShengN_Intel
Glad to hear that your issue has been resolved.
I'll now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Sure, will reflect this to engineering team for further improvement.
Best Regards
Sheng
