17255 Discussions
Quartus compilation problem
Hi all,
I met a strange problem: when i use quartusii,a project first compiled need the Logic Elements is 13%,but then, i compiled again is 1%. :confused:
--- Quote Start ---
Hi all,
--- Quote End ---
Hi cherry,
without any change ???? No design change, no settings changed ....
Kind regards
GPK
this is the main program
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity up3_board1 is
port( datain_adc: IN STD_LOGIC_VECTOR(7 downto 0);--input from ADC
clock: IN STD_LOGIC; -- Clock Input from Altera Board
dataout_serial: BUFFER STD_LOGIC_VECTOR(7 downto 0));--8 bit data for trasmitting
end up3_board1;
architecture BEHAVIOR of up3_board1 is
------------------ COMPONENT UARTTransmitter------------------------------------------------
component UARTTransmitter
port ( txd_data: IN STD_LOGIC_VECTOR( 7 DOWNTO 0));
end component;
------------component UARTTrasmitter------------------------------------------------------
BEGIN
PROCESS(clock,datain_adc)
BEGIN
if datain_adc="00000000"--data from ADC,not correct yet..
then
dataout_serial<="00000000"; -- pH 0.0,fake data
txd_data<=dataout_serial;
elsif datain_adc="00000001"
then
dataout_serial<="00000101";-- pH 0.5
elsif datain_adc="00000010"
then
dataout_serial<="00010000"; -- pH 1.0
elsif datain_adc="00000011"
then
dataout_serial<="00010101"; -- pH 1.5
elsif datain_adc="00000100"
then
dataout_serial<="00100000";-- pH 2.0
elsif datain_adc="00000101"
then
dataout_serial<="00100101"; -- pH 2.5
elsif datain_adc="00000110"
then
dataout_serial<="00110000"; -- pH 3.0
elsif datain_adc="00000111"
then
dataout_serial<="00110101"; -- pH 3.5
elsif datain_adc="00001000"
then
dataout_serial<="01000000"; -- pH 4.0
elsif datain_adc="00001001"
then
dataout_serial<="01000101"; -- pH 4.5
elsif datain_adc="00001010"
then
dataout_serial<="01010000"; -- pH 5.0
elsif datain_adc="00001011"
then
dataout_serial<="01010101"; -- pH 5.5
elsif datain_adc="00001100"
then
dataout_serial<="01100000"; -- pH 6.0
elsif datain_adc="00001101"
then
dataout_serial<="01100101"; -- pH 6.5
elsif datain_adc="00001110"
then
dataout_serial<="01110000"; -- pH 7.0
elsif datain_adc="00001111"
then
dataout_serial<="01110101"; -- pH 7.5
elsif datain_adc="00010000"
then
dataout_serial<="10000000"; -- pH 8.0
elsif datain_adc="00010001"
then
dataout_serial<="10000101"; -- pH 8.5
elsif datain_adc="00010010"
then
dataout_serial<="10010000"; -- pH 9.0
elsif datain_adc="00010011"
then
dataout_serial<="10010101"; -- pH 9.5
elsif datain_adc="00010100"
then
dataout_serial<="10100000"; -- pH 10.0
elsif datain_adc="00010101"
then
dataout_serial<="10100101"; -- pH 10.5
elsif datain_adc="00010110"
then
dataout_serial<="10110000"; -- pH 11.0
elsif datain_adc="00010111"
then
dataout_serial<="10110101"; -- pH 11.5
elsif datain_adc="00011000"
then
dataout_serial<="11000000"; -- pH 12.0
elsif datain_adc="00011001"
then
dataout_serial<="11000101"; -- pH 12.5
elsif datain_adc="00011010"
then
dataout_serial<="11010000"; -- pH 13.0
elsif datain_adc="00011011"
then
dataout_serial<="11010101"; -- pH 13.5
elsif datain_adc="00011100"
then
dataout_serial_1<="11100000"; -- pH 14.0
end if;
end process;
end BEHAVIOR;
the program is when compilation of main program this error comes out
"Error (10482): VHDL error at up3_board1.vhd(34): object "txd_data" is used but not declared"..i already add the component program file UARTTransmitter.vhdl to this main program
any idea???
--- Quote Start ---
library ieee;
end up3_board1;
end component;
BEGIN
BEGIN
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
then
end if;
end process;
end BEHAVIOR;
any idea???
--- Quote End ---
I'm not a VHDL expert, but I think you have to define a signal called txd_data in your architecture.
Kind regards
GPK
GPK
Are you aware you have created a completly asynchronous design? there are no registers in this code.
Also, you have not instantiated a UART Transmitter.
