Quartus crash
Why am I having this problem, anyone have idea pls?
--- Quote Start ---
Problem Details
Error:
Internal Error: Sub-system: FSAC, File: /quartus/fitter/fsac/fsac_ram_packing_estimator.cpp, Line: 130
vacant_slice_capacity >= ram_info.num_slices_required()
Stack Trace:
0x3b7d45: fsac_estimate_num_rams_required + 0x215 (FITTER_FSAC)
0x277c5: ram_core_requirement_count + 0x5c5 (periph_cclk)
0x34c00: CCLK_GEN5_MODULE::create_core_requirements_for_clk_region + 0x1fc (periph_cclk)
0x34f27: CCLK_GEN5_MODULE::create_core_requirements + 0x12f (periph_cclk)
0x40e3f: CCLK_GEN5_MODULE::create_design + 0x287 (periph_cclk)
0xfa88: PCC_ENV_IMPL::perform_op + 0x2ac (periph_pcc)
0xf746: PCC_ENV_IMPL::create_design + 0xda (periph_pcc)
0x2eab9: FSV_PERIPHERY_PLACEMENT_UTIL::do_auto_promote_io_std + 0xd9 (fitter_fsv)
0x21920: FSV_EXPERT::auto_promote_io_std_and_create_complement_pins + 0x50 (fitter_fsv)
0x2570d: FSV_EXPERT::fitter_preparation_pre_fpp + 0xc9d (fitter_fsv)
0x238e6: FSV_EXPERT::fitter_preparation + 0x26 (fitter_fsv)
0x1dfff: FSV_EXPERT_BASE::fitter_preparation_run_family_fitter_preparation + 0x4f (fitter_fsv)
0x1daf8: FSV_EXPERT_BASE::fitter_preparation + 0x68 (fitter_fsv)
0x1e750: FSV_EXPERT_BASE::invoke_fitter + 0x3b0 (fitter_fsv)
0x1c872: fsv_execute + 0x22 (fitter_fsv)
0xe900: fmain_start + 0x900 (FITTER_FMAIN)
0x41b1: qfit_execute_fit + 0x1bd (comp_qfit_legacy_flow)
0x5384: QFIT_FRAMEWORK::execute + 0x2a0 (comp_qfit_legacy_flow)
0x267f: qfit_legacy_flow_run_legacy_fitter_flow + 0x1c7 (comp_qfit_legacy_flow)
0x14410: TclInvokeStringCommand + 0xf0 (tcl86)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5646: Tcl_EvalFile + 0x36 (tcl86)
0x12606: qexe_evaluate_tcl_script + 0x376 (comp_qexe)
0x11864: qexe_do_tcl + 0x334 (comp_qexe)
0x16755: qexe_run_tcl_option + 0x585 (comp_qexe)
0x380c3: qcu_run_tcl_option + 0x1003 (comp_qcu)
0x160aa: qexe_run + 0x39a (comp_qexe)
0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
0x2233: qfit2_main + 0x73 (quartus_fit)
0x12d68: msg_main_thread + 0x18 (CCL_MSG)
0x1454e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x15b00: mem_thread_wrapper + 0x70 (ccl_mem)
0x12631: msg_exe_main + 0xa1 (CCL_MSG)
0x287e: __tmainCRTStartup + 0x10e (quartus_fit)
0x1652c: BaseThreadInitThunk + 0xc (kernel32)
0x2c520: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 7
OS version: 6.1
Quartus Prime Information
Address bits: 64
Version: 17.0.2
Build: 602
Edition: Lite Edition
--- Quote End ---
Only Intel would be able to tell you.
Have you tried deleting the db/ and incremental_db/ folders? if that doesnt work you will need to raise a support ticket.
Hi, tnx for the reply, yes I did delete those folders, also created new project but it is the same.
Edit:
Fixed.
Project I was trying to compile was designed for Cyclone III and not for Cyclone V I was trying to use. By changing settings in existing megafunctions from C3 to C5 everything compiled perfectly either on Q13.0 or last one Q17.02.
