17266 Discussions
Quartus accepts `endif within quoted String "`endif // foo" as endif ?
I am using Quartus Prime Lite 17.0.0 and it accepts the following file:
module ParserErrorV01( input wire D0, output wire LED1 ) ; reg s ; assign LED1=D0 ; `ifdef POSEDGE s = "`endif // foo"; endmodule
Is it right that Quartus accepts macro-conent within quoted strings?
Or is the accent grave ` forbidden in quoted strings? If I remove
the line s=.... Quartus complains that a endif is missing. That is ok.
Qould someone out there perhaps verify my observation with the above content?
Is there an explanation? (I am a FPGA-Noob)
Not correct. You cannot split a string token.
@dave_59
I think you did not understand what I wanted to say. I don't want that Quartus accepts macro content within a quoted string. But I have observed this behaviour and now I am looking ffor an explanation. Is the accent grave forbidden in quoted strings or is there a parser error so that macro content is accepted witin strings.
Ossi
Hi dave_59,
It's not that I would like this behaviour but that I consider it an error. The parser seems to get confused by an accent grave within quoted strings. Could you perhaps verify the behaviour?
Ossi
