17258 Discussions
Quartus crashed on my Windows computer.
finoah
Problem Details
Error:
Internal Error: Sub-system: VRFX2, File: /quartus/synth/vrfx2/vrfx2_ddm.cpp, Line: 6168
uinst
Stack Trace:
  Quartus         0x7d2d9e: VRFX_DDM::create_ddm_connections() + 0xa40 (synth_vrfx2)
  Quartus         0x7d41b0: VRFX_DDM::convert_netlist(VRFX2_TOPDOWN_MGR::ELAB_INST_ENTRY*) + 0x626 (synth_vrfx2)
  Quartus         0x7d5205: vrfx2_ddm_convert_all_netlists(BASEX_ELABORATE_INFO*, Netlist*) + 0xa52 (synth_vrfx2)
  Quartus         0x820225: new_verific::VRFX2_EXTRACTOR::extract_hierarchy(char const*, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, BASEX_ELABORATE_INFO*, bool, bool, bool, bool, bool) + 0x1787 (synth_vrfx2)
  Quartus         0x10da19: QIS_RTL_STAGE::IMPL::elaborate_verific(QHD_PARTITION*, BASEX_ENTITY*, BASEX_ELAB_INFO_CORE&, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, bool) + 0x305 (synth_qis)
  Quartus         0x14ee1d: QIS_RTL_STAGE::IMPL::elaborate_ddm_module(DDM_MODULE*, BASEX_ENTITY*, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, std::vector<DDM_MODULE*, std::allocator<DDM_MODULE*> >&) + 0x10d (synth_qis)
  Quartus         0x14f77a: QIS_RTL_STAGE::IMPL::elaborate_ddm(DDM_MODULE*) + 0x11a (synth_qis)
  Quartus         0x152249: QIS_RTL_STAGE::IMPL::elaborate_ddm() + 0xd75 (synth_qis)
  Quartus         0x152278: QIS_RTL_STAGE::elaborate_ddm() + 0xc (synth_qis)
  Quartus          0x2a8a2: SCMD_ELABORATE::execute(Tcl_Interp*, DTCL_ARGS&) + 0x5aa (synth_scmd)
  Quartus           0xc7da: DTCL_COMMAND_PKG::eval_cmd(void*, Tcl_Interp*, int, Tcl_Obj* const*) + 0x148 (dni_dtcl)
  Quartus          0x4bb47: TclNRRunCallbacks + 0x67 (tcl8.6)
  Quartus          0x4cf29: TclEvalEx + 0x599 (tcl8.6)
  Quartus          0xf40fe: Tcl_FSEvalFileEx + 0x21e (tcl8.6)
  Quartus          0xf4246: Tcl_EvalFile + 0x26 (tcl8.6)
  Quartus          0x270b4: qexe_evaluate_tcl_script(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x388 (comp_qexe)
  Quartus          0x29e08: qexe_do_tcl(QEXE_FRAMEWORK*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, bool, bool) + 0x71b (comp_qexe)
  Quartus          0x2afc1: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x8a5 (comp_qexe)
  Quartus          0x6fb73: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x99 (comp_qcu)
  Quartus          0x6fe66: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x286 (comp_qcu)
  Quartus         0x40703e: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x4b5 (quartus_syn)
  Quartus          0x2fbb6: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x7dd (comp_qexe)
  Quartus         0x406a7c: qsyn2_main(int, char const**) + 0x123 (quartus_syn)
  Quartus          0x43980: msg_main_thread(void*) + 0x10 (ccl_msg)
  Quartus          0x44400: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg)
  Quartus          0x1ff9d: mem_thread_wrapper(void* (*)(void*), void*) + 0x9d (ccl_mem)
  Quartus           0xe178: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
  Quartus          0x44329: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd3 (ccl_msg)
  Quartus         0x406952: main + 0x26 (quartus_syn)
  System           0x3a7e5: __libc_start_main + 0xe5 (c)
  Quartus         0x406879: _start + 0x29 (quartus_syn)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0.19045
Quartus Prime Information
Address bits: 64
Version: 24.1.0
Build: 115
Edition: Pro Edition
RichardTanSY_Altera
I could not find this internal error (IE) in our database. Could you help to share your design .qar file (Project> Achieve Project) that could duplicate this error?
We will need to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
Does this IE occur during compilation flow?
Could you try to run in the latest Quartus version 24.2 and see if the IE still occurs?
Richard Tan
RichardTanSY_Altera
May I know is there any update on this ?
Richard Tan
RichardTanSY_Altera
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you for reaching out to us!
Richard Tan
