Quartus crashes
David32
New Contributor II
I am using Quartus Prime 23.2.0 Build 94 06/14/2023 SC Pro Edition.
Running on Ubuntu 22.04.3 LTS
I have attached the dummy project during which the Fitter crashes.
I have also tried other projects (including example design from Intel) with the same result.
It seems from the attached dump file that Quartus is looking for a file that does not exist.
In fact the entire directory called "20nm" does not exist.
I would appreciate any leads on solving this problem.
David32
New Contributor II
Hi SyafieqS,
1. I attached all files to my original post. Now on vacation for 10 days without access to my work PC.
2. After my posting I found other people reported EXACTLY the same problem - so it is definitely a bug in Quartus.
3. I downgraded to an older version of Quartus and everything is working OK - further supporting my claim that the newest version is buggy.
David
SyafieqS
Hi David,
What is the message?
And I cant see the design attached.
Please reattach it for me to reproduce and take a look.
David32
New Contributor II
Hi SyafieqS,
David
SyafieqS
Hi David,
Noted. You may use it as temp workaround.
Let me know if there is any concern.
I will take a look into the design
