17256 Discussions
Quartus does not recognize bad port declaration
Regarding a given port declaration given like this :
ENTITY john_doe IS
PORT
clk : IN STD_LOGIC;
reset_n : IN STD_LOGIC;
address : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
read : OUT STD_LOGIC := '0';
data : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
request : IN STD_LOGIC;
valid : STD_LOGIC
END john_doe ;
Quartus does not recognize the missing "IN" / "OUT" tag above.
How are these signals handeled ? Does Quartus "look" for the component declaration in the top module, where this entity is used?
Quartus II assume that the port is by default a IN port.
If you try to assign a value to the signal VALID, Quartus II will then return an error saying "that you try to assign a value to a input port"
Why would Quartus II 'assume' anything?
Has anyone filed an SR on this or is this documented anywhere?
Quartus follows the VHDL standard, which says that a port declaration without a mode defaults to IN.
Josh
Ah!.
I love being able to learn something now every day.
Thanks for the reply, I am now a little smarter (?).
Let's hope that the decay rate of the remaining brain cells is less then the learning rate for todays new awareness.
Cheers
It helps to have a copy of the VHDL standard sitting on your desk. :) Personally, I think VHDL would be better off without this "feature". And everyone says VHDL is a verbose language!
Josh
--- Quote Start ---
Josh
--- Quote End ---
Bingo!:) (and another Bingo, to meet the requiriement of writing at least 10 charaters to be able to post)
