Quartus_jli slow .jam
Hi there!
I just wanted to test command line version (quartus_jli).
I now recognized that e.g. a verify takes much more time compared to the GUI-version.
I then programmed a .jam version with GUI-programmer, that takes also much more time than .pof files. Can somebody explain the reason, is there a way to speed up command line operations. I used e.g.:
quartus_jli -a verify -d do_disable_isp_clamp -e do_real_time_isp -e do_bypass_ufm ic11.jbc
Your comments would be highly appreciated :)
kind regards
Stephan
