17263 Discussions
Quartus programmer not working on Windows 11
RobertK
2 issues that I've ran into.
Considering where I worked, most of our machines were pushed to Windows 11.  Thankfully, we had one person who was still on Windows 10.
On Windows 11:
209060 Started Programmer operation at ... 15:55:01
209017 Device 1 contains JTAG ID code 0x31040DD
209044 Erasing MAX 10 configuration device(s)
22050 Operation failed on device 1.  If JTAG secure mode is enabled, retry with JTAG secure mode disabled.
209012 Operation failed
209061 Ended Programmer operation at ... 15:55:01
---   We tested this on 2 different Windows 11 machines..   For the 3rd machine, co-worker had Windows 10 and was able to program successfully.
Issue 2.  On another Windows 11 machine, when attempting to open a file, the file explorer window opens then hangs for a few seconds and the program completely crashes..
Faulting application name: quartus_pgmw.exe, version: 0.0.0.0, time stamp: 0x6171d549
Faulting module name: ntdll.dll, version: 10.0.22000.282, time stamp: 0xb594bedc
Exception code: 0xc0000374
Fault offset: 0x000000000010be99
Faulting process id: 0x3d24
Faulting application start time: 0x01d7dbd33de3858d
Faulting application path: C:\intelFPGA\21.1\qprogrammer\bin64\quartus_pgmw.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: ab929e3f-45f2-4655-85f2-aaaf17d12125
Faulting package full name:
Faulting package-relative application ID:
and
Faulting application name: quartus_pgmw.exe, version: 0.0.0.0, time stamp: 0x614d08a3
Faulting process id: 0x5094
Faulting application start time: 0x01d7db2cbeaabb70
Faulting application path: C:\intelFPGA_pro\21.3\quartus\bin64\quartus_pgmw.exe
Report Id: dce08b96-6889-4a27-b3e3-25998db0f897
NurAiman_M_Intel
Thank you for contacting Intel community.
As you can see in the link below, for now Quartus only support until Windows 10. Engineering team are evaluating this OS support as part of next release cycle.
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html
Aiman
RobertK
Do we know when that next release cycle is?
As it is, most of us can't use the software as we have been migrated to Windows 11.
-Robert
NurAiman_M_Intel
Support for Windows 11 is being reviewed for 22.3 release cycle.
We apologize for the inconveniences.
Aiman
Tom_Troszczynski
Hi
It's bee almost a year since we've learned that 22.3 version will support Window 11. How much longer do You think it's going to take You??
My Corporate laptop just got updated to W11 and I can't do my lab work anymore.
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
J-Raddatz
Hi Robert,
We are encountering similar issues with another software product.  Our work around was to factory reset the Windows 11 machines.  Seems to be working so far.  If you have a found a different solution, please share.
YUL
En Quartus (Quartus Prime 21.1) Lite Edition  el USB Blaster se desaparece, desinstale el programa y borre todos los registros de intelFPGA (con regedit ) y volví a instalar el programa, reconoció el USB Blaster pero al  día siguiente ya no lo reconoció. Hice el mismo procedimiento de desinstalar y borrar el registro de programa, y no he podido lograr que reconozca más al USB Blaster JTAG, aunque el Administrador de dispositivos ve perfectamente el USB Blaster. Claro tengo win11  y como veo, Quartus Prime no funciona bien con win11. Esperemos por ese nuevo lanzamiento. Saludos.
