17266 Discussions
Quartus: "Current netlist is not set" , "SDC Command entered is not currently supporte..."
Zach_Perrizo1
While using Quartus Timing Analyzer, it seems that whenever I try to use most commands in the ::quartus::dcmd_dni tcl package, I get this message:
The command does not return any other string and exits the current process, so it seems to act like an error even though there’s no error code or keyword.
I’m able to see timing reports, instance paths, etc. using other Quartus TA packages, so I don’t think it’s an issue with the design not being loaded. I’ve used these commands in the same package and have a different error when I don’t include the package in the call:
The Quartus TA tool was opened from the GUI after the full flow was run and programming files were generated using the “Assembler” step if that helps. My goal is to be able to run STA commands interactively in Quartus.
Zach
RichardTanSY_Altera
I believe you ran those command in the Timing Analyzer GUI console.
Most of time we run sdc constraint or ::quartus::sta packages' tcl in that console.
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#tafs/tafs/tcl_pkg_sta_ver_1.0.htm#tafs/tafs/tcl_pkg_sta_ver_1.0.htm#tafs/tafs/tcl_pkg_sta_ver_1.0.htm#tafs/tafs/tcl_pkg_sta_ver_1.0.htm
Those commands seem usable in the Quartus GUI Tcl console, not in the separate Timing Analyzer GUI.
Richard Tan
RichardTanSY_Altera
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to let us know.
Thank you for reaching out to us!
Richard Tan
