17268 Discussions
Quartus_syn and nested pragma not supported
TFisc4
I have a bunch of vhdl code which needs to be seen from Altera tools but not others, so I am using "altera translate_on/off" nested inside "pragma translate_off/on" directives:
library ieee;
use ieee.std_logic_1164.all;
--pragma translate_off
--altera translate_on
library altera_mf;  -- Example Altera-specific library
use altera_mf.altera_mf_components.all;
--altera translate_off
--pragma translate_on
-- More VHDL code here
It has been working well for few years with quartus_map. But now quartus_syn has replaced it, and doesn't support nested pragma anymore which throws "unmatched altera translate/synthesis pragma found" warnings before an "unexpected end-of-file" error.
Is there a plan to restore the support of nested pragma ?
Is there a recent version of Quartus which still have the quartus_map executable ?
ShengN_Intel
Pragma is not supported in pro version check this link https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/remove-non-standard-pragmas.html
Intel® Quartus® Prime Pro Edition synthesis does not support the vhdl(verilog)_input_version pragma or the library pragma. Synthesis in other Quartus software products supports these pragmas. Remove any use of the pragmas from RTL for Intel® Quartus® Prime Pro Edition migration.
Remove the pragma and just use it with other synthesis tools. Pro version is more strict.
Sheng
TFisc4
Hi Sheng,
Thanks you for the tip, even though it seems to contradict the documention: Intel® Quartus® Prime Pro Edition Help version 23.1 - vhdl_input_version Synthesis Directive & Intel® Quartus® Prime Pro Edition Help version 23.1 - library VHDL Synthesis Directive
Anyway in my case this is related to the "synthesis_off/on" directives. They are understood by the tool (and you can disable its support if needed), but contrary to others vendors tools and now old quartus_map, the quartus_syn doesn't support nesting it, as in my example.
Thierry
TFisc4
For instance take this code which compiles for both quartus_map✔& quartus_syn✔:
library ieee;
But that one compiles only on quartus_map✔ and fails on quartus_syn with "unexpected end-of-file" error:
library ieee;
ShengN_Intel
The quartus_syn supports nesting but just not support pragma as mentioned in this document link https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/remove-non-standard-pragmas.html
Sheng
