17192 Discussions
Quartus warning 10905 question
FBels
MAX10 design, Quartus Prime Lite ver 18.1.0 Build 625.  I get Quartus  warning "(10905): Generated the EDA functional simulation netlist because it is the only supported netlist type for this device. "
Our local disty Intel FPGA FAE believes it is a library issue.  Should we care, and if so, how is it corrected?  Thanks
KhaiChein_Y_Intel
The setting to specify a functional simulation is not turned on, but this device family supports only functional simulation.
You may ignore this. OR
To eliminate this warning, turn on " Generate netlist for functional simulation " in the More EDA Netlist Writer Settings dialog box.
