Hello ,
I use QuartusII 9.1 (build 222 10/21/2009 SJ web edition) I get the following error when I start to program the EPCS16 (for EP3C25) flash memory I have the following error message: Error: Can't read database file C:/.../.../db/MyProject.sta.rdb But the memory is still programed, and the FPGA runs properly. ??? Is it a problem in my project settings or others .... ??? Thanks in advance for your help cedricLink Copied
