17255 Discussions
QuartusII Error: Please Help me.
this is the first time I use QuartusII: I'm a newbie with FPGA design.
I have installed the Web Edition version 13.1 on a WindowsXP Pro 32bit (Athlon XP+2800, 2GB RAM + 2GB free hard disk space).
When I open the project and select Processing->Start Compilation the "analysis and synthesis" completes without problems but the "Fitter (Place and Route) stops every time at 90% when the "post fitting delay annotation" is running and this error windows is displayed.
The error says:
*** fatal error: unrecognized windows exception
module: quartus_fit.exe
stack trace:
0x13243: tbb::internal::generic_scheduler::get_task + 0x23
0x15020: tbb::internal::custom_scheduler<tbb::internal::intelschedulertraits>::local_wait_for_all + 0x220
0x56eae: tis_re_delay_tree_netlist::is_itt_starting_point + 0x1b0e
0x14fe6: tbb::internal::custom_scheduler<tbb::internal::intelschedulertraits>::local_wait_for_all + 0x1e6
0x56836: tis_re_delay_tree_netlist::is_itt_starting_point + 0x1496
0x54117: tis_re_delay_tree_netlist::tis_re_delay_tree_netlist + 0x4e7
0xa6a4: tapi_root_impl::annotate_atom_netlists_post_fit + 0x234
0xc22e: tapi_root_impl::annotate_all_iterms + 0xae
0x71a8: tapi_root_impl::start + 0x368
0x7994: tapi_root_impl::start + 0x64
0xa4333: fitcc_tdc_utility::initialize_dat + 0x2b3
0xa482d: fitcc_tdc_utility::setup_tdc_utility + 0x9d
0xa6552: fitcc_tdc_utility::fitcc_tdc_utility + 0x1d2
0x38f7e: fitcc_env::get_tdc_utility_or_create_if_necessary + 0x30e
0x1c12a6: fsac_auto_delay_chain_op::work_new + 0x1c6
0x1abe4f: fsac_delay_chain_op::work + 0x22f
0x7db9: fcuda_expert::fitter_post_operations + 0x1b9
0x404ad: fitcc_expert::fitter_post_operations + 0x1ad
0x41e8e: fitcc_expert::invoke_fitter + 0x88e
0x5052: _fcuda_execute + 0x1f2
0xa52c: fmain_start + 0x6ac
0(continued in attached text file)
This error happens also with project examples on the DE0 board CD from Terasic so this isn't a problem caused by my project but it's caused by my computer (hardware requirements or Windows configuration).
Can anyone help me?
Best regards.
I propose to recreate the project from sources, and do assignements manually. Maybe there are incompatibilities in project settings.
Does it happen with EVERY project ? Try a very trivial single one you make yourself (NOT an example).
You can send an Altera Request on www.altera.com
the problem happens with every project I open.
I have opened and compiled the project on another PC (Windows Vista 64bit on I5 core) and it works perfectly so I suppose there is a problem on my PC.
When I installed QuartusII I have deselected "64 bit support" because my PC is 32 bit. Was this module necessary? I don't understand where is the problem.
THe problem with quartus and newer devices is it needs more and more memory. Even though 2GB is the minimum, I would probably recommend a 64bit OS with 4-6GB memory minumum.
Have you tried deleting the DB and incremental DB directories?
if that doesnt work, try contacting altera mysupport.
yes, I've tried to delete DB and incremental DB directories but the problem hasn't been resolved.
I suppose I should install a previous version of QuartusII on this machine if you say that the system requirements are so high.
In release notes (.pdf) of Quartus on www.altera.com, you will see the minimum requirements for each target device.
I had Comodo Defense+ which disturb Quartus.
just for your information I've installed QuartusII ver. 13.0sp1 and my project is compiled correctly. No more errors!
I don't know why on release 13.1 there are so much problems but I will use the 13.0sp1 version.
