17268 Discussions
QuartusII: Invalid assignment for clock
solved
the problem was to leave a space between '10' and '[' :
create_clock -period 10 [get_ports ref_clk_i]
Hi all,
before TimeQuest Analysis, i was setting clock_port named "ref_clk_i" to a signal of 100MHz:
create_clock -period 10[get_ports ref_clk_i]
but appears this error:
warning: invalid assignment for clock: the option -name has the following error: could not identify a name for this clock. clock was not created or updated.
Where am I going wrong?
create_clock -period 10 -name ref_clk [get_ports ref_clk_i]
When you get errors like that, type "create_clock -long_help" in TimeQuest and it usually becomes apparent.
thanks for your answer, but now I've another problem :)
in the same project, I have 2 clocks in input: 'ref_clk_i' and 'clock_i'.
I set up these clocks with tickle commands
create_clock -period 10 -name ref_clk_i [get_ports ref_clk_i]
create_clock -period 1 -name clk_i [get_ports clk_i]
and after that I clicked 'Update the timing netlist', but this is the warning message I received:
warning: the following clock transfers have no clock uncertainty assignment
warning: from ref_clk_i (rise) to ref_clk_i (rise) (setup and hold)
warning: from clk_i (rise) to ref_clk_i (rise) (setup and hold)
warning: from clk_i (fall) to ref_clk_i (rise) (setup and hold)
add the following:
set_clock_uncertainty
(Not sure what version of TimeQuest, but newer ones give a messageand then run it for you.) You might find the following useful:
http://www.alterawiki.com/wiki/timequest_user_guide
you're right, in fact, here's the message I received:
tcl>set_clock_uncertainty
missing required positional argument: <uncertainty>
usage: set_clock_uncertainty [-h | -help] [-long_help] [-add] [-fall_from <fall_from_clock>] [-fall_to <fall_to_clock>] [-from <from_clock>] [-hold] [-rise_from <rise_from_clock>] [-rise_to <rise_to_clock>] [-setup] [-to <to_clock>] <uncertainty>
-h | -help: short help
-long_help: long help with examples and possible return values
-add: specifies that this assignment is an addition to the clock uncertainty derived by derive_clock_uncertainty call
-fall_from <fall_from_clock>: valid destinations (string patterns are matched using tcl string matching)
-fall_to <fall_to_clock>: valid destinations (string patterns are matched using tcl string matching)
-from <from_clock>: valid destinations (string patterns are matched using tcl string matching)
-hold: specifies the uncertainty value (applies to clock hold or removal checks)
-rise_from <rise_from_clock>: valid destinations (string patterns are matched using tcl string matching)
-rise_to <rise_to_clock>: valid destinations (string patterns are matched using tcl string matching)
-setup: specifies the uncertainty value (applies to clock setup or recovery checks) (default)
-to <to_clock>: valid destinations (string patterns are matched using tcl string matching)
<uncertainty>: uncertainty
I surely have to add something
Sorry, I typed it wrong. Use:
That will auto-calculate all the uncertainties between clocks. No need for set_clock_uncertainty.
ok, in fact here's the message:
tcl> derive_clock_uncertainty
Info: Clock uncertainty calculation is delayed until the next update_timing_netlist call.
I've created the .sdc file and I've added it to the project;
I restarted the compilation and I noticed that the number of warnings is decreased, but however remains this:
and I don't know why.
Can you help me?
