16627 Discussions
QuartusII - Missing drive strength and slew rate
Hi all,
in a complete project compilation, I solved all errors and warnings;
there remains only this:
warning: some pins have incomplete i/o assignments. refer to the i/o assignment warnings report for details
watching on the PIN assignment, I see this on all output PINs:
missing drive strength and slew rate
but the strange thing is that on the slew rate column of the pin report, I see those PINs with the slew rate value of "2(default)", assigned by Quartus by default.
What can I do to remove this last warning?
Thanks to all
set values of drive strength and slew rate in Assignment Editor, then these assignments will be complete.
