17257 Discussions
Quatrus recognizes localparam struct field referencing as a hierarchical identifier referencing
SKaza4
typedef struct { int unsigned size_of_smth; etc. etc.; } param_t;   localparam param_t PARAMS = `{ size_of_smth : 4, etc : .... };   typedef logic [PARAMS.size_of_smth - 1 : 0] smth;
Quartus shows the following error:
Error (10742): Verilog HDL error at some_file.svh(12): constant expression cannot contain a hierarchical identifier
PARAMS.size_of_smth is a constant, so I think it should be supported
MuhammadAr_U_Intel
Hi, Can I know what version of Quartus are you using Standard or Pro Edition and which specific release 18.x ? Thanks, Arslan
SKaza4
I'm using two versions:
Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Standard Edition
and
Quartus II 64-Bit Version 14.0.0 Build 200 06/17/2014 SJ Full Version
Both of them produce the same error
Siarhei
Hazlina_R_Intel
I apologize for the overlook on this case. We had an internal transition issue and the engineer overlooked this case on his plate. May I know if your request still outstanding? I can then decide on the next course of action for this case. Thank you.
SKaza4
I found workaround. But I think this issue requires attention.
Hazlina_R_Intel
Thank you for letting me know. Would you mind explaining to me what the workaround was? I can use that information for the verification at my end before I submit a ticket to engineering for the bug fixing or enhancement.
KennyTan_Altera
can you provide two design.qar for us?
1) design.qar that can replicate the error
2) design.qar that had your workaround
SKaza4
This is a project with the error
SKaza4
This is a project with my workaround
KennyTan_Altera
Thanks for your input. I will feedback this to the engineering.
