公告
Questa install not working
djmohab2
新手
7,602 次查看
I have downloaded the install archive several times, un-installed, and re-installed Questa, and when I start the program, it gives me a command shell and exits out. Here is the install log. I need assistance ASAP as it is for an important deliverable.
Sincerely,
David
标签 (1)
0 项奖励
24 回复数
ShengN_Intel
员工
6,512 次查看
May I know which operating system you're using?
Have you specify the questa license path with LM_LICENSE_FILE in Environment Variables?
Sheng
0 项奖励
djmohab2
新手
6,497 次查看
23.4, and yes I have.
I have set the LM_LICENSE_FILE as a System Variable, pointing to the path in which the LR-XXXXXX_License.dat file resides.
Running Questa, I get :
Unable to checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Running the lmdiag utility gives the following:
lmutil lmdiag
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
FlexNet diagnostics on Mon 2/19/2024 22:52
Can't fetch the requested Information!!
Kindly re-check the license file path and server details.
Please advise.
-David
0 项奖励
sstrell
名誉分销商 III
6,476 次查看
How old is your license file?  Open it in a text editor and check the date.  It's only good for a year.
0 项奖励
djmohab2
新手
6,458 次查看
I generated the license file on Sunday.
0 项奖励
ShengN_Intel
员工
6,447 次查看
May be try to regenerate the license file and make sure correct NIC ID and computer name.
0 项奖励
djmohab2
新手
6,388 次查看
I tried that, and double checked NIC and computer name. Can I get some actual assistance instead of the equivalent of turning it off and turning it back on again? The testbench I was provided and told to validate is protected and only valid for Questa. Otherwise I have to write my own testbench from scratch. This is ridiculous that I can't get an actual solution to a problem that is clearly the fault of the program's.
0 项奖励
ShengN_Intel
员工
6,338 次查看
I tested without problem check attached screenshot. May be try download the individual file and install. Make sure using the correct license file which is Questa*-Intel® FPGA Starter Edition (License: SW-QUESTA). One more thing is make sure you're using the supported OS environment.
Sheng
0 项奖励
ShengN_Intel
员工
6,300 次查看
Do you have any further concern or consideration?
Sheng
0 项奖励
djmohab2
新手
6,285 次查看
Yes, I have concerns as your advice has not actually done anything to help address them. I am running Windows 11, which as far as I know is a compatible OS. What individual file are you talking about? I downloaded QuestaSetup_23.4.0.79-windows directly from your portal.
The fact that you tested without any issues is irrelevant because that information does not fix or give any help to solving my issue at all.
0 项奖励
ShengN_Intel
员工
6,256 次查看
How about using the command setx LM_LICENSE_FILE <path_to_license_file>;%LM_LICENSE_FILE% in command prompt to set the LM_LICENSE_FILE link https://www.intel.com/content/www/us/en/docs/programmable/683472/23-4/and-software-license.html any different?
Sheng
0 项奖励
djmohab2
新手
6,156 次查看
C:\Users\David Mohabir>setx LM_LICENSE_FILE C:\intelFPGA_pro\license.dat; %LM_LICENSE_FILE%
ERROR: Invalid syntax. Default option is not allowed more than '2' time(s).
Type "SETX /?" for usage.
No, nothing different. Can you actually make your product work? This is getting embarrassing.
0 项奖励
djmohab2
新手
6,151 次查看
I even installed it on another computer, my laptop, rather than my desktop and I get the same exact problems. And yes, I double checked to make sure I was generating a license against the Starter Edition.
lmutil lmdiag
FlexNet diagnostics on Sun 3/3/2024 20:33
This is ridiculous.
0 项奖励
ShengN_Intel
员工
6,145 次查看
The error because of space between LM_LICENSE_FILE C:\intelFPGA_pro\license.dat; and %LM_LICENSE_FILE%.
If setx successfully, the problem still exists. Please provide your computer name and NIC id to me, I'll help to generate the license. I notice that your license name is different compared with mine.
Sheng
0 项奖励
djmohab2
新手
6,141 次查看
setx LM_LICENSE_FILE C:\intelFPGA_pro\license.dat;%LM_LICENSE_FILE%
Don't think it's the space causing the problem there. Can I please get some actual assistance from anyone? Every suggestion you have given me has literally done absolutely nothing to alleviate my issues.
0 项奖励
ShengN_Intel
员工
6,121 次查看
I'm ok without the space one. Check screenshot:
0 项奖励
djmohab2
新手
6,116 次查看
Okay, somehow despite the fact I did try it without a space before, I tried it again, and I got the same success dialog you did. However, upon trying to start Questa again:
lmutil lmdiag
FlexNet diagnostics on Sun 3/3/2024 22:36
0 项奖励
ShengN_Intel
员工
6,113 次查看
Can you provide your NIC id and computer name? I help you re-generate a new license file for Questa Starter Edition
0 项奖励
djmohab2
新手
6,104 次查看
DJDEADNUTS
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek USB GbE Family Controller
Physical Address. . . . . . . . . : 64-C9-01-B7-48-DF
0 项奖励
ShengN_Intel
员工
6,101 次查看
Your Host Name is DJDEADNUTS?
Possible to provide the Host Name like stated in screenshot below:
0 项奖励
djmohab2
新手
6,093 次查看
Windows IP Configuration
Host Name . . . . . . . . . . . . : DJDEADNUTS
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : fdf3:3d70:bcf6:c006:4197:b02a:b5c6:ed4f(Preferred)
Temporary IPv6 Address. . . . . . : fdf3:3d70:bcf6:c006:c5d0:80a7:338d:e55f(Preferred)
Link-local IPv6 Address . . . . . : fe80::c845:ba1b:95fd:e140%22(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.68.63(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.252.0
Lease Obtained. . . . . . . . . . : Sunday, March 3, 2024 9:22:45 PM
Lease Expires . . . . . . . . . . : Monday, March 4, 2024 12:22:56 AM
Default Gateway . . . . . . . . . : 192.168.68.1
DHCP Server . . . . . . . . . . . : 192.168.68.1
DHCPv6 IAID . . . . . . . . . . . : 375703809
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2A-BC-1D-B1-8C-1D-96-CC-3F-3F
DNS Servers . . . . . . . . . . . : 75.75.75.75
75.75.76.76
NetBIOS over Tcpip. . . . . . . . : Enabled
0 项奖励
回复
