17241 Discussions
Questa not opening GUI when following Questa* Intel® FPGA Edition Quick-Start: Intel® Quartus® Prime
Fast_Eddie
I’m working through “Questa* Intel® FPGA Edition Quick-Start: Intel® Quartus® Prime Standard Edition” tutorial, and I get to the run simulation stage per https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/launch-simulation.html - according to the log file, the simulation was spawned:
Info: Start Nativelink Simulation process
executing command line: ip-make-simscript --nativelink-mode --output-directory=PLL_RAM_iputf_input --spd=C:/FPGA/Quartus_STD_LITE_PLL_RAM/ClockPLL.spd
========= EDA Simulation Settings =====================
Sim Mode              :  RTL
Family                :  cyclonev
Quartus root          :  c:/intelfpga_lite/23.1std/quartus/bin64/
Quartus sim root      :  c:/intelfpga_lite/23.1std/quartus/eda/sim_lib
Simulation Tool       :  questa intel fpga
Simulation Language   :  verilog
Simulation Mode       :  GUI
Sim Output File       :
Sim SDF file          :
Sim dir               :  simulation\questa
Info: Starting NativeLink simulation with Questa Intel FPGA software
Sourced NativeLink script c:/intelfpga_lite/23.1std/quartus/common/tcl/internal/nativelink/modelsim.tcl
Warning: File PLL_RAM_run_msim_rtl_verilog.do already exists - backing up current file as PLL_RAM_run_msim_rtl_verilog.do.bak1
Info: Spawning Questa Intel FPGA Simulation software
Info: NativeLink simulation flow was successful
But the Questa GUI does not open, so I can’t go look at the results/waveforms as suggested.
Any idea what I’m doing wrong?
Fast_Eddie
Ok, I have sussed it - license failure.  Forcing setting the environment variable for the license file in a batch file immediately before launching Quartus seems to make sure Questa can see it.  Pity Quartrus just hides the Questa standard output so you never see the error message
Fast_Eddie
RichardTanSY_Altera
I believe you can invoke the Questa standalone software (not through Quartus) to check for any license checkout error message.
I'm pleased to know that your issue has been resolved.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you and have a great day!
Richard Tan
